Diagnosis
1978 911 SC 140K
Sat for about 8 years
went to a reputable shop, got the once over, ended up needing new head studs, new spark plugs, new oil thermostat, new alternator, replaced oil lines, some oil line kinks removed.
I have been driving the car for the last 6 months and noticed the following, relatively consistently:
a few drops of oil (4-6) after I park it
usually notice some oil smell with the heat on
typically smokes from the rear oil cooler and passenger side heat exchanger once parked for a few minutes
estimated gas mileage is in the 15 MPG range
new wrinkle:
I typically drive around 3500-4000 RPMS with the temp gauge being about center or slightly above center
last week I ran her at close to 4500 RPM's for about 30 minutes straight and noticed the temp gauge creeping well above center, though not into the red
I have also been trying to closely monitor the oil consumption, it seems like I am using around 1/2-3/4 quart per 300 miles
It seems like all signs are pointing at possibly a top and bottom end job, but given the headstuds were all replaced I would think that most issues should have been caught when that work was done, so kind confused
I am planning on getting a compression and leak down test ASAP
please overwhelm me with thoughts...
Old 08-16-2012, 04:28 PM
tazzieman's Avatar
1. Clean engine of all built up grunge, top & bottom - fin clogging can reduce cooling effect. Good threads on how to do this.
2. After a spirited drive , get under the engine at night with a strong torch and look carefully for seapage e.g. oil return tubes etc etc
3. Get the comp & leakdown to assess how old this engine is - with diagnosis you can plan for treatment
btw what type/weight of oil are you using?
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 08-16-2012, 04:38 PM
Castrol GTX 20w-50
Old 08-16-2012, 04:44 PM
Dublinoh's Avatar
Just to be clear: a torch is a flashlight.
Old 08-16-2012, 05:18 PM
tazzieman's Avatar
And everyone in the ROW knows a flashlight is a torch
Old 08-16-2012, 05:22 PM
so that giant cut I just made in my muffler with the acetylene torch is not going to solve my issue?
Old 08-16-2012, 05:30 PM
tazzieman's Avatar
Now go and have a look around the fuel tank...
Old 08-16-2012, 05:33 PM
HarryD's Avatar
1978 911 SC 140K
new wrinkle:
I would not worry too much yet.
How hot was the ambient temp when you saw the elevated temps?
While you have higher temps they are not critical. If it was me, I would clean both coolers, change to a better oil (brad penn or joe Gibbs), and watch how things progress.
As far as the few drops, does not sound like a biggie.
FWIW, my car uses about 1 quart/1000 miles.
Old 08-16-2012, 05:42 PM
