| SLR |
				Jack for Porsche
			Hi all I need a replacement roadside jack for my 1985 911, I brock the jack it came with. I was looking at a scissor jack with a jack pad, but not that happy with that. a BMW used with the M3's looks ok ? Any ideas? Thanks Steve. | ||
|  08-18-2012, 07:08 PM |
| Registered |
			i use a regular small honda scissor jack with a stud welded on top. so you can jack it up right in the hole  under each a-arm . I did that so i dont have to jack it up so high to get the wheel off the ground which i have always found to be a problem on any car in a roadside tire change when your in a rush. and it works great the only downside is you have to crawl under the car.
				__________________ 82 SC , 72 914 | ||
|  08-18-2012, 07:27 PM |
| Registered Join Date: Jan 2006 Location: Clayton NC
			I use the aluminum scissor jack from a 944.  Smaller and lighter.  Carry a couple pieces of wood for support.  The boss on top of the jack fits into the corner jack points on 87-89 Carrera.  Porsche dismantlers should have lots of them for not many $.
				__________________ gary 70T coupe forever almost done 88 Carrera Targa diamond blue | ||
|  08-19-2012, 03:10 AM |
| Northern Motorhead |
			Same here for the aluminium 944 jack ... I cut a hole in the center of a hockey puck and use it as a pad that fits on the tab of the jack ! Cheers ! Phil
				__________________ Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 | ||
|  08-19-2012, 08:51 AM |
| Swapper and Ruiner Join Date: Oct 2009 Location: Katy, TX
			Mine is for sale.  Interested?  $50.  It's from an '86 H
				__________________ http://forums.pelicanparts.com/paint-bodywork-discussion-forum/502929-diy-iroc-rsr-conversion.html http://forums.pelicanparts.com/porsche-911-technical-forum/649179-rsr-ls-conversion.html | ||
|  08-19-2012, 01:22 PM |
| muck-raker Join Date: Jan 2009 Location: Coastal PNW
			that's interesting.  Does anybody have the part number for the 944 aluminum scissor jack?
				__________________ STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.  Deny Everything; Admit Nothing; and Always Make Counter-accusations   | ||
|  08-19-2012, 02:14 PM |
			I bought mine on Ebay from Planet Porsche for $40.00 dollars ... Do a search,there's always a few for sale ! Cheers ! Phil
|  08-19-2012, 02:39 PM |
| Registered |
			There are a bunch of them on e-bay.  If you want the parts number, it's probably on the parts diagram link from Pelican's New Parts Catalog.
|  08-19-2012, 04:23 PM |
| Registered User Join Date: Apr 2012
			looks like there are two types .. one that is flat on top with a slit and the other type have a raised bump... which one would work best on a 70t?
| AutoBahned | |||
|  08-19-2012, 05:30 PM |
| Banned Join Date: Aug 2012
			i use a regular small honda scissor jack with a stud welded on top.    | ||
|  08-19-2012, 05:41 PM |
