-   -   Little numbers in electric sheets (http://forums.pelicanparts.com/porsche-911-technical-forum/6966-little-numbers-electric-sheets.html)
Zendalar 08-09-2001 05:30 AM
Ok, I am looking at these electrical thingie sheets at pelican. There is also the legend part, but it does not explain what are the little numbers. It only tells the bigger, the ones inside a circle.
What are the little numbers and where do I find a legend for those?
Bill Verburg 08-09-2001 07:28 AM
I'm not sure which little #'s you are refering to but if ite the ones which are in the middle of the wire it is the cross sectional area with the color code beneath. If its the ones at the bottom of the page it is the circuit #.
<font color="#730000">Bill Verburg</font>
My Home Page http://www.pelicanparts.com/ultimate/icons/icon15.gif My Pelican Gallery page http://www.pelicanparts.com/ultimate/icons/icon15.gif My Porsche Owners Gallery Page
Early_S_Man 08-09-2001 08:17 AM
Zen,
I'll take a guess, and assume you are talking about '73 and earlier diagrams, which are 'geographical' in nature or laid out so the top othe diagram is the front bumper, bottom is back bumper, etc. Not too many circuit numbers, except interupted ones to worry about, as Bill was referining to '74 and later 'Current Flow' type diagrams ... with both circuit numbers and page numbers to worry about!
There are two types of numbers on the older diagrams other than the circled device numbers.
1. The most numerous are terminal or pin numbers on the individual devices.
2. For wires that go a certain distance (interupted circuits) and just stop without connecting, and there is a number right at the end of the wire, that circuit goes to the other page, this is most common with fuse blocks and gauge/instruments on the dash.
Luckily about diagrams conforming to the German DIN standards, terminal numbers on devices are somewhat standardized, and can be found in publications like the Bosch 'Automotive Handbook,' and some other technical publications. Unfortunately, some types of devices, such as relays, switches, and ignition coils have terminal desinations that have changed somewhat over the lifetime of the Porsche company.
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
