Speedy Gonzalez
Fan 5 Blade VS Fan 11 Blade
Can someone give a explanation of the diference between 5 blade fan VS 11 Blade fan.Thanks Tony
Exactly 6 blades.
Jeff Jensen 1973 911 |
Flat Six
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Porsche 911 Buyer's Guide - Randy Leffingwell - Google Books
If you're pressed for time...
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
muck-raker
highly recommended to switch to 11 blade. I believe the housing must be replaced as well.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
