PeterTarga's Avatar
'S' hose cutted need advice abbout oil cooler
Hi,
When I drove last my car a 911SC Targa Euro 78 and came home I saw suddenly a huge amount of oil on the floor in my garage, lucky there was just a little bit on the road. From what I could see the S hose was cut.
Now I did remove the S hose and I have doubts that I have the original cooler on my SC there for I need some advice, do i need to install another cooler or ... bought this car 9 years ago, and two years ago the S hose was replaced.
Some pictures say more than words :
http://users.telenet.be/jos.aerts/S%20hose.jpg
http://users.telenet.be/jos.aerts/oil%20cooler.jpg
Old 08-19-2012, 07:19 AM
To me, that looks like an original cooler with an aftermarket hose...
Old 08-19-2012, 07:52 AM
RETIRED
Joe Bob's Avatar
Buy a good hose, not a 'URO', don't use Permatex.
2012 ML350 3.0 Turbo Diesel
Old 08-19-2012, 07:55 AM
PeterTarga's Avatar
Hi, I did not install the hose and the Permatex was from the previous owner, can you give me the details of the hose that I should install
Thanks,
Peter
Old 08-19-2012, 08:51 AM
If you have a 78 SC, from your second pic, you do not have the correct oil cooler. That is an early oil cooler 71 or earlier. SC oil cooler does not have the threaded fitting. Maybe the reason for the sealant is that the fit is not correct and there was leakage. Also, follow the advice above and DO NOT buy the cheap S hose.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 08-19-2012, 09:12 AM
Oh, and if it were me, I would install the correct cooler. If the S hose comes off you will lose a lot of oil quickly. Your early cooler, if pressure tested, has value. Good used coolers are available.
gary
Old 08-19-2012, 09:19 AM
kodioneill's Avatar
That's a screw on cooler, incorrect for that year as this guy says.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 08-19-2012, 09:24 AM
PeterTarga's Avatar
Thanks for the good advice, I will look for a correct replacement and a order a good S hose
Old 08-19-2012, 10:30 AM
Canyon Runner
70SC's Avatar
Porsche Crest S hose
Look up Len at Boxster GT . He will make up just about any hose you may need . y
Old 08-19-2012, 11:29 AM
BoxsterGT's Avatar
Porsche Crest
I would be happy to make up an adpter pipe to properly connect a S hose to your early cooler with a threaded fitting like this...............
However, it would be much better to buy a correct 911 slip-on type cooler as used with 72 and later models like this one...............
Tom1394racing has used ones that are cleaned & pressure tested and guaranteed good and at a fair price. Look him up and get a correct cooler for your motor.
Then you can buy the original "S" rubber slip-on hose from Porsche directly or our host. Don't buy a aftermarket product from China, they are junk. Buy only an original.
Len
Old 08-21-2012, 10:23 AM
