-   -   to chip or not to chip (http://forums.pelicanparts.com/porsche-911-technical-forum/697334-chip-not-chip.html)
Capt Rick 08-21-2012 10:33 AM
I am looking to acquire a little more performance from my stock 3.2 , i am being told that its not a good idea to rechip due to the OEM rod bolts etc,etc, don't have the same temper as todays replacement parts. the the power plant is original with 76,000 org, miles on a 1984 911 carrera targa i welcome your input thanks, Rick
rick-l 08-21-2012 10:41 AM
Here's a couple the search function drug up.
http://forums.pelicanparts.com/porsche-911-technical-forum/659959-steve-wong-chip-advice.html
http://forums.pelicanparts.com/porsche-911-technical-forum/685734-steve-wong-chip.html
ejp 08-21-2012 11:17 AM
NooooooOOOooOOOoooo! (also, which oil should I use and why?)
http://www.standupamericaus.org/sua/...of-worms-o.jpg
The links from rick-l should explain :)
ivangene 08-21-2012 12:08 PM
$50 you can play with this...I ran it for over a year...it seems to be a little more peppy - but I switched out back to stock while looking for another "issue" which turned out to be unrelated
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/639758-autothority-3-2-chip-60-obo-shipped.html
Cooper911SC 08-21-2012 06:14 PM
Just drove an '87 3.2 with 130K on it "before" and "after" chip. Made a nice difference. The typical 3.2 throttle tip-in lag was gone and made a slight difference in overall acceleration after 4,000 rpm.
You won't hurt the motor.
kidrock 08-21-2012 06:57 PM
oh gawd, here we go....get your popcorn ready....
Jack Olsen 08-21-2012 10:45 PM
The smart money on a Carrera: Cat bypass, sport muffler, and a Steve Wong chip. This is tried and true.
clutch-monkey 08-21-2012 11:38 PM
bought steve wong chip for my car, with some trepidation.
went to put new chip in, turns out it already has one in there, so it's already been chipped for god knows how long.. so clearly steve wong chips have no affect on the longevity of your engine!
put the new chip in anyway, fixed the stalling issue with the flywheel and alloy pressure plate haha
JJ 911SC 08-22-2012 01:37 AM
Chip thread calling Loren... Over
ant7 08-22-2012 03:42 AM
Steve Wong, or Loren, read up on both, and then decide.SmileWavy
I made my decision and went with Steve, no regrets!
Anthony.
Chuck.H 08-22-2012 04:21 AM
I've had a modified chip in my car for over 300k miles, no problems yet but of course it's too early to tell. :-)
I have Mass Air flow (no barn door) - chip - SSI headers - M&K mufflers (in that order!) and my engine is a blast with this combination. Maybe the actual HP or torque is not radically different, but drivability and fun-factor is waaay improved.
As others have said, these engines really wake up with a little more timing advance.
Chuck.H
'89 TurboLookTarga, 338k miles
NY65912 08-22-2012 04:35 AM
+1000 on SW
ejp 08-22-2012 06:17 AM
I've found this chart very useful for my 3.2 mod planning:
http://forums.pelicanparts.com/uploa...1300740229.gif
It was borrowed from this thread.
hcoles 08-22-2012 06:57 AM
good table.
Looks like a chip gets you ~15hp at 6k. That is probably a noticeable amount. Another way to look at this, does it really change your life? Are you now going to out run other cars you meet on the street? Does it turn the car into a 10HP to the ground per pound full up? I realize this is a wet blanket sort of post, but really where are you going with this? I trust SW 100% if the ~15HP is important to you, do it.
CCM911 08-22-2012 07:10 AM
I really like that table! It is like a "chinese menu". Chose one from column A, one from column B.....
For dumb folks like me, this is good stuff.
K.I.S.S. - Keep it Simple Stupid....
Dublinoh 08-22-2012 07:17 AM
Originally Posted by hcoles (Post 6927902)
good table.
I don't disagree with your logic but my reason for considering the SW chip is the reports of smoother acceleration...reducing "dead" spots.
MMiller 08-22-2012 09:31 AM
+1
That was worth it for me.. And turns out it was true.
Otto 08-22-2012 11:42 AM
Read here for insights into the actual reality which few if any mention:
http://forums.pelicanparts.com/porsche-911-technical-forum/683503-performance-tuning-myth.html
SilberUrS6 08-22-2012 01:25 PM
Originally Posted by Otto (Post 6928429)
Read here for insights into the actual reality which few if any mention: [fiction trimmed]
"Actual reality"? You mean "bashing for the sake of selling a competing product?"
vracer 08-22-2012 06:05 PM
Installed the SW chip a few weeks ago. My butt dyno says there is a moderate amount of improvement, but it just might be because my butt is closer to the seat.
