75 911S Hot Air Hold Down
Folks - I have seen some cars that use a small washer with an extended section that allows the hose clamp to pass thru it and hold the hot air hose in place. It appear the piece goes under the bolt that holds down the shroud. Not a Porsche part. Anyone seen or have sourced one of these? Photo attached shows one of these i use. Think I can make one but prefer a pro fabrication if possible - Thanks - Steve
Old 08-25-2012, 10:22 PM
