rob justice's Avatar
front/back fuel and brake lines
front/back fuel and brake lines - has anyone changed them? and if so is it the nightmare it looks?
Old 12-23-2002, 10:58 AM
Somatic Negative Optimist
Gunter's Avatar
Cool
Use the proper wrenches and counter-hold the brake lines where needed. Consider caliper rebuild, SS lines, while you are in there. Check rotors, bearings, etc. and have fun. Don't know about fuel lines.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-23-2002, 11:27 AM
atlporsche's Avatar
surprisingly no,
I did my 912's front to rear fuel line...it was a PITA to feed through all the other stuff, but it worked.
I had to get stainless line from the hardware store becasue it was the only way I could get more than 60"...you need at least 72 to run front to back.
sjd
Porsche sold, moving back to muscle cars for a bit.
Old 12-23-2002, 11:32 AM
its the lines inside the tunnel that i mean - did a simular job on my old vw beetle and had to end up running the lines outside the tunnel because it was so difficult
Old 12-23-2002, 11:57 AM
cary's Avatar
I did the fuel lines, when I had the engine out. Really pretty easy. Used the old ones as my fish tape. Being paient, and gentle they came right thru.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 12-23-2002, 04:12 PM
addictionMS's Avatar
I just put in two AN -6 brained stainless steel lines into a 1970 chassis, needed a return line for the 3.2l (hehehe) and one I had pulled out the shifter, brake/heater ass. and opend up the ****er coupler cover it was pretty easy. however I did have the motor out at the time, so take that into consideration. everything is accessable with the motor and trani in.
If you are replaceing to restore you can't use AN-6, but if you are replacing to improve you can.
Jim
Old 12-23-2002, 05:41 PM
BYantzer's Avatar
Just did my rear brakelines this afternoon, not that difficult just time consuming.
Brad Yantzer
81 SC
87 944s (dead, burnt it up)
Old 12-23-2002, 06:13 PM
