Distributor
Hi , I have a porsche targa 1970 2.2t with a merilli distributor, I'm trying to do the timing but can't seem to move the distributor to get the correct timing , I have loosened the nut and a smaller securing nut but still won't move , is it just stuck , thanks . Pud
Sounds like it's seized to the engine casing. Shoot some WD40 on it and see if it will free up.
I had to use a little slap hammer with a hook on the end of it once. A little tap hammer also might free it up. Just be careful as it will mark up the dist housing. Kevin 86 coupe |
Distributor
Hi, thanks for the reply, I've put loads of WD around it and trying with hammer and screw driver to widge it between holding plate but still rock solid ,
Perhaps running the engine a bit to warm it up might help free it?
Good idead, will do that , thanks ,
When I do finally get it free I would like to do the timing , not sure what marks are meant to line up with the mark on the fan shroud ,
