G |
G |
Looking at it from a different angle, making sure you engine is running as well as it can will probably net you a few ponies. CIS can have air leaks, distributors bushings and wires get tired. Warmup regulators can control the fuel in a non-optimal way, etc.
I found the most satisfying improvements were fixing the bugs that made it run less than perfect. It's a pretty cool car as-is. I am pretty sure you can advance the distributor a wee bit for better response but I have not done this. If you search there is info on it. |
However if you are looking at doing a 3.2 or 3.6 upgrade or other HP mods, now would be the time to look ahead and do it right one time. |
The turbo brake upgrade is $$$. It was one reason I pulled the plug on my SC - blowing $3k on brakes looked like a good opportunity to sell the SC and put the $3k towards a 993 (which came with big reds ;)) G |
78 should have big valve heads
IMO Remember to save all of the SMOG equipment you remove because THE MAN will be sniffing you tailpipe sooner or later. Kalifornia has it 76 up so 74 back is an E-Ticket here. Also Clean stock early SC cars are climbing in value these days. A 78 should have the big valve heads and that is a good thing for you. Static CR(compression ratio) is decent on a 78 too. IMHO start low buck with an SSI, muffler of your choice, & re-degree the stock SC cams. If the SSI & muffler is out of budget or too much hassle look at the by-pass tube & maybe a muffler. Pelican has the AIR Block Off Plugs. Your CIS is not evil and the 964 cams(and reground rockers) are probably the upper limit to avoid low RPM/idle issues backing up thru the intake valves with CIS. My techo junkie neighbor with the WORKS MINI is always asking if I want to sell the old 911 hot rod with a Euro 3.0 & SSI. Clean looking SC. Make yourself happy:) and enjoy the ride.:cool:
| All times are GMT -8. The time now is 06:42 AM. |
