Need advice on what power source (safe) to use for a Jacobs Omni Magnum
I'm looking for a good 12 Volt source located in the engine compartment to power the Jacobs Omni Magnum. Any ideas/recommendations?
Jacobs Omni Magnum SmileWavy |
Is it too late to return the it?
:D |
ANYONE?
Well I just hooked up my MSD and I sed the power at the rear fuse panel. I don't know about the Jacobs unit but MSD only draws like 5.8 - 6.7 amps so I don't see a problem. Also it is constant 12v . Good luck.
Use the 12V wire that you disconnected from your stock coil primary, that's what it's for.
Cheers, Joe |
This is NOT a coil.
| All times are GMT -8. The time now is 05:19 PM. |
