who's got the cheapest carrera fuel line?
i'm in need of the $500+ line under the carrera intake. i don't want to rebuild in this case. someone posted previously about one for $300+.
John, Is this the one:
Check this source http://catalog.eautopartscatalog.com/europroducts/wizard.jsp?partner=europroducts&clientid=eurowebparts.com&baseurl=http://www.eurowebparts.com/&cookieid=0OI13SRY1&year=1986&make=PO&model=911--006&category=E&part=Fuel+Line They list it for 340.00, maybe Wayne will match or beat it.
Bruce Herrmann 97 C4S '04 330i '08 Cayenne S '07 4.8 X-5 |
John, it is an easy rebuild. Behind the factory crimps are nipples on each end of the hose. Hence, regular fuel-injection line can be used with fuel-injection clamps. I have since put 1000 miles on my rebuild.
Just an FYI
Nick '85 Carrera |
Senior Member
Lets find three or four "cores," overhaul them and switch them out as they start to leak on our cars. If we could find a few old units to use as cores they could be overhauled and kept ready as needed.
I like to support Wayne and Pelican but some F.I. hose under three feet long and six crimped ends are just not worth $350+ in my book! This is not rocket science here! Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
gibson, thanks, that's the one. i know they can be rebuilt, but the customer wants a new one.
This is the post I had in the past on this fuel line.
3.2L with huge gas leak -- how bad? That special is now over so it's back to the "normal" price of $340. http://www.eurowebparts.com/default.asp?url=porsche/default.htm Hope this helps
Harold 89 911 Targa, 96 Saab 900S, 02 Passat 1.8T Wagon 02 BMW 530i, 08 Cayman, 17 GTI DSG 19 Subaru Forester |
Senior Member
John,
Could I buy the old fuel line when you get it out? Will start a "overhaul program" myself and after changing mine out will be happy to do the same for other guys. Thx, Joe
Author of "101 Projects"
Our price on this is $299... Got one coming tomorrow for Mr. Walker...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
Senior Member
Kurt,
On any hose like this you can usually cut off the crimps using a dremel or very fine hand saw. Then take it to a good hose shop, diesel truck places usually have them. They have fuel hose that can replace the stock hose and with the same or higher pressure ratings and crimp them on and pressure test them at the same time. You can also use stainless steel hose like is used on the race cars but the covering is only for show. Only problem I could see with this type of hose is that you cannot see the outside of the hose, and thus cannot see when its getting old. Only way is when it actually starts leaking, and then it may be too late. FI clamps are the ones that many car makers use on their individual injectors to hold the hose. Much higher quality and have never had any problems with them, but would prefer a crimped hose. Joe
