Quick 3.2 Carerra Relay Question
Hey all,
I just need clarification on the relay layout, car is an 84 Europe 3.2
The car died last night, turns over but wont start - I suspect DME relay so have ordered another from our host already but got me wondering about the Relays in the Trunk,
I suspect the fuse cover is from an older model possibly SC? As it states relay 1 & 2 are Fuel pump, from reading ive been doing, the 3.2 doesn't use a relay in the trunk for fuel, as the DME relay handles it, and slot 1 is supposed to be unused.
If so, what are the relays in 1 & 2 on mine being used for? and what should the correct layout be, would be handy to get it sorted out and marked on my cover in-case of future problems.
This is my Fuse box -
And Cover -
Thanks!
Old 04-08-2014, 07:20 PM
83 911 Production Cab #10
JJ 911SC's Avatar
From the Bentley.
Since the car was working I would not dive in too much in there (until you replace the DME relay) except maybe clean the fuse/holder one at the time.
Do get the Bentley book it will pay off in no time.
Does the VIN confirm it's an 86?
Who Will Live... Will See
Old 04-09-2014, 02:32 AM
Thanks! I will get the Bentley book shortly, haven't had the car long so have been collecting, have 101 projects already!
I found the not starting problem this evening, engine temperature sensor was faulty, dme tested fine with a jumper in its place. I will keep the new one as a spare when it comes.
Car vin checks out as an 84' so the fuse box is still pretty confusing, I would like to figure it out so I know what's doing what. Anymore help on that would be great
Old 04-09-2014, 02:44 AM
JJ 911SC's Avatar
It does look like an SC fuse box with no Fog Light (Relay #2) & no Cruise Control (Relay #4) but since the VIN confirm its an 84.
I'll check the Porsche Manual to see if there is any variant.
Old 04-09-2014, 02:47 AM
