si2t3m's Avatar
Distributor ID and ignition woes
Hi.
The Bosch PN is 0 237 303 003
It doesn't have a vacuum unit and il looks like it never had one.
I'm just wondering if i'm using the correct distributor rotor and cap thats why I want to id the dizzy.
I've took it apart & cleaned it. resistance on the magnetic pickup terminal where the green wire goes is 575ohms After reading some posts, took it off again to center the reluctor star. Good thing this board is here!
I'm still trying to get it to run right. Engine has webers and MSD ignition. Finally got the webers synched and ajusted 4 of the air mixtures. 2 (#2 & #3) did not register any change when closing the idle mixture screws. Took the carb apart again, checked every passage, everything is ok. Took the strob light and checked every wires. Seems like i'm getting intermitent spark on 4 of the cables
Cables are new (the ones from vertex @ 69.00) ... I do know that MSD says not to use solid core wires... Are these solid core?
TIA
Marc-Andre Morin
914-6 conversion 3.0L, Webers
Old 05-29-2002, 08:06 PM
