-   -   Who Sells Floating Rotors? (http://forums.pelicanparts.com/porsche-911-technical-forum/69900-who-sells-floating-rotors.html)
TurboRuf 05-28-2002 08:13 PM
Who sells 12.75"x1.25" front floating rotors for the 80's 911/930 type hubs?
The more sources the better... thanks. :)
Jack Olsen 05-28-2002 08:36 PM
I specifically need the 78-79 930 fronts, and they are a bear to find. The best I've found is $520 for the pair.
Nader 05-28-2002 10:04 PM
Jack: Does that price include the center flange? I understand the flanges are $800 each.
Jack Olsen 05-28-2002 10:17 PM
Probably not. I use a custom hat, since I have 930 brakes on an early 911.
I guess this would all fit nicely in the "How many other ridiculous prices?" thread. :)
TurboRuf 05-29-2002 07:20 AM
Jack,
Is that through VCI?
dtw 05-29-2002 07:32 AM
Guys,
I know my wrench can get them. He did the brakes on my friend's 78 930 last year. Cubic dollars, but he can get them. The center flanges are $$$. The ones on the 78 had some cracking but he said it was not an issue and put them back in without replacement.
Try giving him a call at 919.851.5084, ask for Tolga, tell him Dave sent you. His pricing is always very fair.
Bill Verburg 05-29-2002 03:57 PM
VCI sells aftermarket floating rotors both drilled and/or slotted. For oems you need to contact a dealer or Brembo
Steve Weiner at <a href="http://www.easystreet.com/~porsche/">Rennsport</a> is another good source which I like due to the availability of anodizing on the rotors
bdonally 05-29-2002 05:43 PM
I think that Coleman Racing will make anything you want. I have had good experience with them - they just don't really want to mess around with road applications.
http://www.colemanracing.com/prodex/cat.htp?cat=Brakes%20%28Rotors%29
I put 330mmx30mm rotors on my Audi - I designed and made the ahts and sent Coleman a drawing of the rotor - they arrived in a week, fit perfectly, and were about $125 piece. They offer a floating design.
I will probably go the same route when the 930 rotors on my '84 Carera need replacing.
dean 05-29-2002 06:10 PM
I bought floating rotors for my car from Hendrick Porsche. $250 each. I got the hats from a place in NJ. $200 or so. Both are nice guy to deal with. I also heard that the corrosion protection is better on OE rotors vs OEM.
82SC 05-29-2002 07:17 PM
can you give info on the hats place in NJ???
MJ
dean 05-29-2002 08:29 PM
http://www.pwr-tech.com/index.html
Here is the link for Powertech in NJ.
I talked with Mike.
I think the hats themselves where $200 plus hardware, so the total was around $300
Sorry for the brain fade
