Fuel filter is on!
Any secret to get the bottom 17mm fuel line nut loose while counter holding the filter? I have tried and tried and that sucker isn't moving. It's a 87 3.2 . Any help is much appreciated!
Use some penetrating lube....
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
83 911 Production Cab #10
I had to remove it with the line attach and it took a lot to get the nut out on the garage floor.
Do not use heat
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Remember, LEFTY LOOSEY.
Use two wrenches one one the body of the filter and one on the line nut. Separate them by enough that you can wrap you hand around both. With your hands, close the gap by holding the wrench on the filter still and moving the line one clockwise (lefty loosey). It will move. |
+1 on taking the lines out with the filter and separating them on the garage floor. I have an "82 turbo and getting two wrenches / arms in around the intercooler was brutal. Good thing I took the lines out too because I had to stand on the wrenches with the filter on the floor to break the bottom seal. The filter had either been put on extra snug by the PO or it spent a few years within a hot engine compartment and had become frozen to the fitting. You don't want to strip the fuel line fitting.
Thanks guys...I did think heat. But a little person in my head said NO!
![]() I will try spray buster and wait a day to get the desire to swear and sweat again. |
too many projects 1983 sc
ben ![]() ![]()
The Dude abides...
Just changed out my fuel filter and holy crap was it on there tight...I guess the PO didn't want any gas leaks coming from the filter.
![]() It did finally come loose with a fair amount of coercion.
Steve '03 Carrera 4S |
I know what you mean. So far I haven't tried it again so it's been easy! Going to give it a try as soon as my 56 yr old back recoups!
