Does anyone know where I could browse for used parts for my 911? All of the junkyards I have spoken to say they do not know where to find used body parts, I am specifically looking for the rusted common panels underneath, and suspension parts. (also wheels.) I would think there would be a couple places that specialize in this...
-Rickeolis- 1986 Corvette |
Unregistered
Where do you live? In Southern California there are a few dismantlers who specialize in Porsches.
I'm in New Mexico. I usually have to send off for everything I need, so distance is not an issue. Can you name a couple as an example? Thanks-
Try these dismantlers: www.911pcar.com/ or www.20thstreetauto.com - I have bought a few things from 20th Street, here in Phoenix.
I do remember seeing an ad for an engine a while back from 20th St.
Thanks, I'll check these out!
Author of "101 Projects"
A lot of the panels are cheaper new than used - check out our Chassis section:
http://www.pelicanparts.com/catalog/shopcart/911M/por_911M_chasis_main.htm -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne, you are right. I've called around for both new and used, and compared all of the prices I was quoted and found that your prices for the panels that I need (ie. front suspension pan+) are better. You have beat all of the new panels $$, and even one quote I got for a used set. You'll see my order very soon- Thanks.
I was able to remove the old panels during this long weekend we just had, I see I need a few other things while I'm at it
Senior Member
Wayne,
How about new fenders and front hood for a 70-72 model? Was just at 20th street and they have a lot of 911 cars there and a good selection of used parts. Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Montana 911
How is the repair going?
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Real good, (did you get my e-mail; from this mornin'?)
I jacked the car up, took the gas tank out, took the front wheels off, and began extracting the panel where the front of the 2 swing arms mount, in front of the tank. I got that panel and the one in front of it, (shaped sort of like a taco,) then found one of my battery boxes was too far gone as well. Now I'm in the process of using a lot of Naval Jelly on the remainder of the area. I do like that the fenders and headlight boxes look just fine.
Friend of Warren
Rickeolis, here are some previous threads on the front suspension pan replacement you might find helpful: Advice on replacing front Pan
Suspension pan replacement
Kurt V No more Porsches, but a revolving number of motorcycles. |
Montana 911
Wow Rick, sounds like you are right on track!!!
I am not too sure that I would even attempt that much of a repair, but if it came down to it I would try. I did get your email and sent a reply.
Thanks Kurt, those did help. I appreciate it-
Hello Smitty, wire brush work this weekend, see you soon.
