-   -   Which return spring should I have??? (http://forums.pelicanparts.com/porsche-911-technical-forum/700322-return-spring-should-i-have.html)
haveacamper 08-30-2012 03:44 AM
I have a 1981 UK 911 SC engine and i'm trying to figure out if I have the correct return spring. i have a vertical orientatied short throttle return spring, but not sure if its a) the correct spring and b) whether I should have this return spring aswell/instead:
911-110-165-02-M100
Pelican Parts - Product Information: 911-110-165-02-M100
my short spring connects to the throttle body and butterfly
the one above appears to connect to the pivoting part of baseplate
any pictures of what it should look like would be much appreciated.
cheers guys
Nathan
Flat6pac 08-30-2012 04:43 AM
That spring connects to the underside of #1 or #2 air runner and goes to the accelerator console on top of the engine to return to idle. You need both
Bruce
haveacamper 08-30-2012 04:48 AM
blimy! its quite stiff to open the throttle up by hand using just the one spring i have already!
it rotates very easily with no spring - so may be i have the wrong spring.
any chance of a pic? so i can see how it connects?
