GaryR's Avatar
Send a message via ICQ to GaryR
Fan ratio for an SC?
Anyone know what a stock SC fan drive ratio is? I'm guessing around 1.5:1 but i'm sure someone here knows the accurate number.
Gary R.
Old 08-31-2012, 10:05 AM
Fleabit peanut monkey
Bob Kontak's Avatar
The 78 US 930-04 / US California 06 / Euro SC 03 all had 1.81 to 1.
Direct from the little Tech Spec book.
Old 08-31-2012, 10:16 AM
Bill Verburg's Avatar
'78 SC 930/13 or /15, fan ratio is1.8
How's the car?
Bill Verburg
Old 08-31-2012, 10:20 AM
GaryR's Avatar
How's the car?
Figured it would be you answering that Bill..
Few hours on the celette, new hood, bumper, lights, headers, some bondo and paint, and she will be like new!
Gary R.
Old 08-31-2012, 10:25 AM
RETIRED
Joe Bob's Avatar
What....Bob is invisible? Funny looking, yes....
2012 ML350 3.0 Turbo Diesel
Old 08-31-2012, 11:15 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Some of us still like you.
More light reading to beat the subject to death.
Engine Fan Drive Ratio
Do a search Gary, you lazy..........
Kevin L
'86 Carrera "Larry"
Old 08-31-2012, 11:23 AM
Grady Clay's Avatar
Gary,
The ’78-’79 911SC ratio is speced 1.81:1 with the largest (134 mm) crank pulley and a ~84 mm fan split-pulley.
However, it has the smaller 226 mm fan.
With the small fan, the air flow is specified as 1380 liters/second at 6000 rpm crankshaft speed.
Best cooling is using this pulley arrangement with the (earlier & later) 245 mm fan.
This is speced as 1500 l/s @ 6000 rpm with a 127 mm crank pulley.
Using the (~80 mm) fan hub from a 5-blade fan on the 245 mm fan and your 134 mm crank pulley, you can increase the ratio a bit more than 1.8:1 and get air flow in the (perhaps) 1700 l/s range.
These are very desirable combinations for a street 911 where one needs increased cooling of the engine machinery (cylinders & heads) at driving speeds.
For track use, your small fan (even at the earlier 1.3:1 ratio) and the Rubbermaid Solution is ideal.
This almost does away with the need for a front cooler.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 08-31-2012, 11:55 AM
