tach removal ?
Can the tachometer on 911 ('87) come out without removing the steering wheel or entire column? I can push the tach out (through speedo opening), but I cant figure out a way to get it all the way out. seems the steering column/wheel is in the way. can I get it out all the way by just removing the steering column cover (plastic housing cover)? I have a 3-spoke Porsche steering wheel. I think it is std size. or will I need to take off the wheel and all?
Thanks.
'87 Carrera Cab |
I KNOW someone knows this one. anyone? thanks.
'87 Carrera Cab |
I've had the tach out of my '80 SC about five times now. I didn't have to remove my 3 spoke wheel. Your Carrera could be different from an SC, but I doubt it.
-Rob 1980SC |
I'm waiting for the answer myself. I looked at mine the other day and it looks like - at the very least - the plastic housing around the column will need to come off. Anyone? -- Curt
I leave the plastic shroud on the steering column. Just pull it straight out, then to the right until you can rotate it around enough to remove the wires.
-Rob 1980SC |
tach removal
I changed my guage faces to white. Manuevered to tach out, but had to remove steering wheel to get it back in. Sorry for the news, but it's no biggy. Pull the center horn pad off, unplug the wire from the horn pad, turn wheels straight forward, remove nut that holds the wheel on (24mm I think). Asseble in reverse. Good luck.
Toga82sc |
i just rotated my tach and encountered the same problem. don't think that you can get the tach all the way out without the removal of the steering column. sad but true. so i guess that changing the lights in the instruments in my 88 carrera is going to be much more invovled than i originally expected.
db
oversteer...there is no substitute |
thanks!! I'll try the column plastic cover first, take it from there. not sure how to "pop" the steering wheel cover off but I'll take it slow if necessary. I HAVE to clean out the inside of the tach glass. it's looking terrible and will fog up often. I think the gunk adds to the fogging (like a dirty window). wonder why some get dirty inside and others are clean. I thought about rotating the tach too. what is the "official" 12 o'clock setting? beginning of redline? or rpm at peak of torque chart? middle of redline?
'87 Carrera Cab |
Why, I attempted this job last night and concluded the wheel must come off and probably the lever assembly housings as well. This is a job for daylight hours, though no biggie.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
How in the world is Rob getting his out without removing anything? Maybe the early cars are different (71). It looks to me like I could pull my tach straight out only about 1/2 inch, then it would hit the column housing. -- Curt
I guess my car is special. I've had my tach out no less than five times in the past three months replacing light bulbs and trying to get the the needle to stop bouncing. It just pulls right out without removing the stock three spoke wheel or the shroud on the column.
Sure is strange how cars that are both earlier and later than mine are unable to do this. -Rob 1980SC |
It'll be legen-waitforit
Rob,
I don't know what kind of mojo you have, but I either hit the underside of my dash cover, or the steering wheel. Had to take off the wheel to get at the gauge (the "club" method worked great for whomever put it up here) Once off though, you might start thinking of a new steering wheel...
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
I'm in the same camp as Rob - when i had my troiuble with the broken mounts a few weeks ago, I went behind the tach to check the shear bolts. Getting it out was no problem, though it was infinitely easier to do without the wheel in the way. Removing the steering wheel is such a simple operation (now that I've got the 27mm socket and extender) that I did it for the convenience.
Emanuel
"Motorcycles... the cigarettes of transportation." Seth Myers |
Author of "101 Projects"
Just remove the wheel, it takes 5 minutes:
http://www.pelicanparts.com/techarticles/Mult_Steering_Wheel/Mult_Steering_Wheel.htm -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne-
thanks for reply but that article doesnt seem to cover removal of horn cover on 911. I have 87 911 with a 3-spoke Porsche wheel. I dont think it was original b/c I think they wee 4 spoke but I do think it's a Porsche wheel perhaps. I'll try to attach a pic
'87 Carrera Cab |
You are correct - its not a stock 87 wheel.
Randy '87 911 Targa '17 Macan GTS |
There is an entire article in the most recent (Aug,02) Excellence devoted to this subject matter.
I'm another one who gets mine out WITHOUT removing the steering wheel -3 spoke steering wheel- 77 Car
But Removing the wheel is easy enough so do what you need. Shawn
Shawn 77 Targa with 2.7 My never-ending work in progress that has been off the road since Mar 2004
