I have re-ringed many alusil motors (some for racing).
I did not have to re-ring mine as the end gaps were well within tolerance. Although, top end rebuild was premature because of head stud failure.
I have an '83 small port CIS motor and went from the 9.3 USA pistons to the euro 9.8's... also with 964 cams.
Dont be tempted to run too much timing. I have detonated pistons getting too froggy with advance, the car just feels great until smoke bellows out the tailpipe. :) I ran the same CIS without any changes for years, however I have Webers now. |
With all the potential problems with the increased 9.8:1 c/r, for the minimal gain it seems to give, it no longer seems to be worth it to me.
So, I think I've been convinced not to change the pistons/cylinders at all and reuse my existing 9.3:1 alusil ones. It seems alot of people have gone this route with good success, including some reputible shops. In fact below is Ollie's response to me in this regard: Hi Matt, We've been using Sunnen equipment for many years now that has a process to handle Alusil honing. Please give us a call and we can discuss the process with you - ask for George. Ike Plus this seems to make my engine rebuild budget much more managable. Thank you all for the info, especially the ones who provided the additional info on PM's. |
good info from Ollie's, I'd love to know what they charge to process Alusils
Looking forward to hearing how your rebuild turns out |
Unanswered in all this is the question of how much benefit the Euro 9.8s will give over the US 9.3s if you don't run the big port heads and runners.
It seems pretty obvious that you will pick up a bit of power, but not as much as the Euro motors, right? When the US motors switched to the smaller intake ports and runners in '80, the Euros kept their setup as it was. And when they went to the 9.8/1 with the big ports, they got the advantages which made them able to run with the 3.2s. On the other hand, bumping the CR from 8.5 to 9.3, but making the ports smaller on the US motors ended up with the HP basically the same. Me, I would not go out of my way financially to switch to the 9.8/1 if I wasn't also going to the big ports and runners. All moot for me, though, as I run my '82 SC in a stock engine class. All I did when I rebuilt it was buy a new set of Nikasil Mahles to replace the Alusils. |
| All times are GMT -8. The time now is 05:29 PM. |
