Power windows addition help needed
Hi,
I just bought a 1975 911S. It has power sunroof, mirrors but not windows. I found window regulators with motors out of an SC, but I'm not sure what's required as far as wiring. Do I need to add a relay? Can anyone help me with a wiring diagram maybe? Any help would be appreciated. Thanks! --MJ |
bump.
Anyone? |
You'll need the center harness that spans the width of the dash and then one door harness for each door. You'll also need the three window switches and the relay and relay wire harness on the fuse panel. It's not really hard to install, helps if the doors are off the car. The holes for the wires to pass through are already in the doors and the door jamb. It wouldn't hurt to have a schematic also. Have fun !!
Thanks for the info. Do you know where I could get the schematic?
Thanks! |
e-mail me your postal address and I'll send you a photocopy. Or if your near Van Nuys give me a shout at the shop and you can pick it up there. You'll also be able to inspect a couple cars to get an idea of how the wires run.
Automotive Innovations and Restoration |
Sorry, mispost.
Thanks for the help. I live in the valley so I'm not too far from you. I will stop by and pick up a photocopy. Thanks much!
--MJ |
I may have a line on all the hardware you'll need to install the system, wires, switches, etc. Let me know what you need and maybe we can make a deal.
| All times are GMT -8. The time now is 12:59 AM. |
