964 Distributor Drive Belt
How long should it take a Porsche Tech to install this belt?
I am asking only because I live 100 miles from Dealer and will have to wait or make
other arrangements.
Old 09-06-2012, 12:12 PM
Racer
winders's Avatar
other arrangements.
Ask the dealer you are taking it how long it will take. How long it "should" take means little. If the dealer doesn't have a tech that knows how do it it, it will take longer.
I would think you would be better off going to an independent shop for this. There is a pin that you need along with the belt:
930-602-134-00 Porsche Toothed Belt (964 distributor)
930-602-922-00 Porsche Distributor Gear Pin
The belt is an aftermarket part now. The pin is still a Porsche part.
Scott
Old 09-06-2012, 12:27 PM
There used to be a guy in Atlanta that does this on the side. Look at this thread.
Distributor Belt Replacement - HOWTO?
You can also do it yourself. Just follow the instructions here: Dual Distributor Belt Replacement
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 09-06-2012, 12:52 PM
i read that article and the part about disassembling the belt driven side is not necessary. you tap the locating dowels out of the way and separate the housings a bit, then the belt can be slipped in. takes about an hour and a half if you know what you're doing. a dealer tech probably doesn't.
206 637 4071
Old 09-06-2012, 01:50 PM
