A/C "recirculate" mode??
So is there any sort of "recirculate" mode to the stock A/C system like a "normal" car has or does it only blow cool air in the cabin from the outside?
Mine works pretty well but I can 't seem to tell and it would be nice to pull some humid air out of the cabin while blowing dry air back in. |
It's always recirculating air. It pulls it into the evaporator from a hole under the passenger floor board.
JR |
Ah, cool! (well, sort of "cool"). Good to know that.
Here's a related question then: how does that other knob work on the ac controls? I had thought it blended in outside (or otherwise warmer) air...?
If the cabin is "super-heated", triple black and setting out in the Texas sun all day, you may want to run the fresh air intale blower for the first few minutes of operation, or/and with the windows down.
If you want to cool the car down quickly simply open all the windows and sun roof if you have one; ie. if the outside air temp is 99F and the cockpit is 125F, the outside world can suck the heat out of the car quicker than the fresh air cooling fan. So....., open the windows, start the car, drive down the road, and when the cockpit feels as cool as it can get then turn on the ac (turn both thermostat and evap blower knobs fully clockwise; this will clear out the residual heat soaked vents quickly) and when the vents start to feel cool then you can start closing up the windows and adjusting the thermostat and fan speed to your desire.
The Mr. Ice Project |
JR |
I never ran mine at less than full blast on both knobs. But then again, I live where it's hot...
JR |
Since outside ambient air cools a cockpit sooner than the ac system could its not logical to load up the evaporator with hot cabin air. |
Every Lexus I have owned, still own, has had an automatic climate control system that in "this" situation, close up, hot sun, super-heated interior, will immediately go into full A/C blower and start fully cooling, CHILLING (34F "target") the A/C evaporator, air reheat/remix door fully closed, and place the system in full recirculate.
My "job" is to, as quickly as I can, place the system in "fresh" while simultaneously lowering the rear windows slightly. Within a few minutes I raise the windows and if I wish maximum efficiency from the A/C I switch the system back into recirculate mode. So, yes, there will be a minute or so wherein the evaporator cooling system will be inordinantly burdened with the over-heated airflow but it will also be helpful in more quickly reducing the temperature of the cabin atmosphere. |
"laws of physics'... well Wild West let's hear the law of physics, Please quote the scholars: Sir Benjamin Thompson Sadi Carnot Rudolf Clausius Ralph H. Fowler .... we are waiting patiently, all of us... lol |
I really do enjoy leaving the less educated "hanging"!
AIR CONDITIONING HELP and review "The AC Temperature Switch - An example in detail with a typical 911 Porsche" |
What I expect to see in the sign glass as the compressor starts up is "clear", then a brief transition to bubbles, then clear again as the transition to liquid refrigerant occurs. |
The mental image I get is my physical chemistry professor in full facepalm. |
| All times are GMT -8. The time now is 11:05 PM. |
