charles
Foglights and other electrical gremlins
Hi
I'm working through a few electrical issues with a 73.5 911.
I've had the alternator rebuilt and replaced the VR with a solid state version.
This cured alt light on always.
This morning I noticed that the alt light glowed weakly at idle - this is the first time I have seen this since replacing the alternator/VR??
Foglights:
Pulling the FL switch I don't get lights or the red indator on the switch to light.
If I jump power from fuse 1 directly to the FL fuse (8 I think) I get lights on.
The relay appears to be OK: I swap it for the horn relay and the horn works.
Turn signals/fuel gauge:
With turn signals on, the fuel gauge bounces in sync
Ignition switch:
I have to have the key in just the right position to energize the starter.
Does this indicate the key is worn, or the switch is going south?
Appreciate suggestions.
Charles
Old 09-13-2012, 12:19 PM
Electrics
Sounds like an earthing problem.
There are a group of earth connections, behind or around the car radio. ( They tend to break). look there first, alternatively, clip an independent earth to the gauge etc and see if this cures your problem.
As for the ignition switch, I suggest that you buy a replacement at Porches grossly inflated prices, or check the non genuine route.
Fuse connections are generally an issue for lighting problems. I replaced my fuseboxes with the blade type, a bit of a fiddle, but cost me about £15... $25?
Old 09-14-2012, 11:09 AM
