| Jim Sims |
06-01-2002 01:58 PM |
If you pushed the reset button while the car was moving you may have stripped an odometer gear or broken a gear attachment to a shaft. If this is the case a repair will be in order; it can be a DIY job if you can obtain the gear but the VDO company apparently makes it difficult for the DIY person to obtain one. Sometimes a gear will apparently just loosen on a shaft (plastic expands or cracks due to time and heat?) and slip and the odometer will stop logging. This happened to me last summer in my '76 during a very hot crossing of Wyoming. The odomter stopped logging for about 30 miles then resumed and has worked ever since. The speedometer/odometer repairs can be done by various companies; I believe Pelican can arrange such repairs. Probably at least a $100 with a speedometer calibration. Jim
