SMHemmah
69 911 intake manifold
My 69 911 intake manifolds have a hole in the front manifold and a hole in the back manifold. The passenger side has a vacuum hose between the two holes. My driver side has open holes. What should I do with the open holes.
Bird. It's the word...
It sounds like you have Sportomatic intake manifolds. You should be able to blank them off with a bolt and aluminum washer.
John Forcier Current: 68L 2.0 Hotrod - build underway |
SMHemmah
Fishcop
Thanks. That is what I was thinking. Seem the holes have a purpose for another type fuel system - Not Weber. Take care Steve |
