M rear caliper orientation
I have a 1968 911 it has the dual bleeder M rear calipers. Do the bleeder nipples go up or down on these ? thanks
Old 09-06-2012, 07:09 AM
rw7810's Avatar
bleeder screws should be up.
Robert Williams
70' 911T
Old 09-06-2012, 07:46 AM
djpateman's Avatar
Air bubbles rise, so the bleeder always has to be at the top.
If you have the dual bleed rear caliper with cross-over tube, then I am sure the caliper is an L type. The L, M & S refer more to the pad type than to the actual caliper. For example, the M calipers all took the M pad, but came in many different configurations with 38, 42 and 48 mm pistons, front or rear applications, spaced for vented rotors or not and several different castings.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 09-07-2012, 05:52 AM
