-   -   Speedo working Odometer dead any help?? (http://forums.pelicanparts.com/porsche-911-technical-forum/703032-speedo-working-odometer-dead-any-help.html)
flyn-hawn 09-07-2012 11:36 PM
Was driving today filled up gas and reset trip odometer, took off from service station and odometer and trip odo stopped working. Speedometer is working fine but mileage and trip have stopped functioning. It is in an 81 SC coupe. never had an issue with this until today. Any suggestions??
Thanks,
Dave
timmy2 09-08-2012 12:40 AM
Pelican Parts Technical BBS - Search Results
7 pages of answers for you to read through. :)
Tech article is here:
http://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/89-Odometer_Repair/89-Odometer_Repair.htm
porwolf 09-08-2012 01:21 AM
Thanks,
Dave
Same happened to me. I read all the threads here on Pelican and came to the conclusion that I will have North Hollywood Spedometer do the repair. It is about $125.-
neighbour 09-08-2012 03:24 AM
Speedo
Poorwolf is right.
One of the most common things w/Porsche soeedo.
They can re-calibrate it when fixing the gear if needed.
cobra935o 09-08-2012 06:09 AM
I took mine apart to attempt the repair, didnt have the results I wanted and ended up sending it to North Hollywood Speedo, was like 160 (only about 3-4 months ago price) with the return shipping, works like a champ, now I dont reset that trip odometer unless I am stopped, since the seemed like what made it break in the first place. It also took about two weeks for them to turn it around.
Richard C2S 09-08-2012 06:26 AM
Yep. Same thing just happened in my '81 SC. I probably caused it by resetting the trip odometer while rolling out of a gas station. I know it can be fixed locally, but I will send it to North Hollywood so it can also be recalibrated.
vracer 09-08-2012 09:38 PM
I just had my '89 Carrera odo done by Palo Alto Speedo. Hartmut said that it makes no difference if you are rolling or stopped. It is just a weak gear.
flyn-hawn 09-08-2012 10:59 PM
thanks for all the advice, I appreciate it!
