Delusions of Adequacy
Wheel Spacer Install
First of all - this is turning out to be more exhausting than the SSI install!
The crux of my issue: I am installing 21mm wheel spacers on the front of my 74 911. I removed the OEM 52mm wheel studs and installed the 72mm studs just purchased from Pelican. Upon reinstallation of the wheel, I fell like I may be hitting the top of the lug nut inside with the stud before the wheel is absolutely positively secured. It's really hard to tell, but I am definitely threading further into the lug nut than I did with the original 52mm studs and no spacers. I just feels weird, and a little to close for comfort. I did take the car for a spin around the block, and checked it when I returned; still on there good. Any wisdom out there for me? Should I purchase longer/taller lug nuts? Thanks in advance for any helpful opinions...
1974 911 3.0 (makes me )2004 Toyota Sequoia 2000 Honda CBR XX1100 Blackbird |
How about using open lug nuts?
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
"O"man(are we in trouble)
If you are using 72's you are bottoming out the alloy lug nuts. Use open end steel. I don't believe they make long deeper alloy lug nuts.
Rescuer of old cars
Are 66mm studs correct for 21mm spacers? I'd like to use a pair on the rear of my '84 to fill the fenders better.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Well - that kinda sucks. To reiterate the question above - I'm guessing that I should have gone the 66mm route then, right? If so, I may just order the 66mm and install; I like the look of the closed end lug nuts.
