pkfrdh's Avatar
Question Help!! Has anyone installed an electric rt. side mirror and actually wired it in?
Help!!
I'm still stuck trying to figure out how to run wiring for the right side mirror in order to be able to use driver side toggle to control passenger side electric mirror.
Anyone know how to or have a schematic that shows in a relatively simple way how to connect the left directional switch to the right mirror through the changeover switch in the middle? How much of the original loom (if any) in the dash is used for this install and why is there only three contacts on the switchover rocker switch (one for ground and two for power?)? Does anyone have a conversion kit schematic (does that even come w/ a conversion kit?) that they can e-mail from flatbed scanner? I am going to wire in new wire where needed instead of buying Porsche loom...too expensive. Any help greatly appreciated.
Thanks.
PKF
Old 06-03-2002, 04:10 AM
