What's wrong with this wheel bearing?
I installed new front wheel bearings just a few months ago. When I took my rotor off, this is what the bearing looked like. What went wrong? Yes, I know how to pack and adjust bearings. I do track the car aggressively, but they shouldn't go bad this fast. The only other thing I can think of is excessive heat from the brakes dragging due to the Ti shield issue.
Old 06-30-2002, 07:40 PM
It does look like a product of heat. What type of grease did you use? Also, is that from the side that was pulling when you braked?
Old 06-30-2002, 07:51 PM
stormcrow's Avatar
Has the bearing in the pic been cleaned or washed in gas?
Old 06-30-2002, 08:02 PM
Early_S_Man's Avatar
Thom,
What brand and type of wheel bearing grease did you use? Many have questioned my recommendations to use the highest-quality, high-temp rated moly grease on wheel bearings ... but your example of dragging rotors makes the case quite well! If you used a plain white, red, blue, or giolden-colored lithium grease ... I think you have your answer!
Whether or not the Ti shields played a role ... seems doubtful to me!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-30-2002, 08:18 PM
This is from the side that pulls. I was using Valvoline HiTemp all-purpose bearing grease - the red stuff. I've been using this for years and haven't had bearings that looked this bad.
Where would one get the SuperDuper grease?
Old 06-30-2002, 09:32 PM
Porsche Crest
Thom,
I got my Valvoline #986 SynPower Synthetic Grease with moly ... claims to meet all US, Japanese, and European specs for CV-joint grease ... at Wal-Mart!
Warren Hall, Jr.
Old 06-30-2002, 09:57 PM
rickeolis's Avatar
Porsche Crest
Could this be due to too much torque? (On the outer nut)
-Rickeolis-
1986 Corvette
Old 06-30-2002, 10:01 PM
dickster's Avatar
just a thought 'cause i'm just about to get mine done.
did you change the outer parts that are pressed into the hub? if so, how'd you get the old ones out of the hub and new in???
Rich
'86 coupe
"there you are"
Old 07-01-2002, 12:15 AM
Yes, I changed the races as well:
http://vintagebus.com/howto/wb/
Old 07-01-2002, 06:51 AM
dickster's Avatar
what are the black speckles (just visible on the roller) just right of the centre roller?
Rich
'86 coupe
"there you are"
Old 07-01-2002, 01:40 PM
Are they German bearings??? They don't look discolored from overheating, just kind of worn. Are both sides the same? Can you feel any of the wear marks with your nail? How do the races look?
Tinker
Old 07-01-2002, 06:26 PM
the vintagebus link showing photos of bearing replacement has some issues. 2 problems. never remove race using a screw driver...you can see all the dings and scratches to the hub. also, don't use a socket to install the race. better to spend the money and get a bearing puller and use a race installer. it's important...photo shows a porsche...i think u can afford these special tools
Old 09-07-2012, 07:45 PM
GaryR's Avatar
Send a message via ICQ to GaryR
I use Mobil Red synthetic, never saw anything like that!
Gary R.
Old 09-07-2012, 08:01 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If both the bearing and race were replaced....then I would suspect the bearing was installed just a little tight.
If you clamp the bearing too tightly...you force the grease out of the rollers.
Even experienced mechanics get it wrong sometimes....tighten until drag occurs then back off so that it rolls smoothly but not sloppy.
Bob
Bob Hutson
Old 09-08-2012, 12:02 AM
kodioneill's Avatar
10 year old thread guy's.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 09-08-2012, 05:46 AM
Is there a problem with commenting on an old thread? Just wondering, I never saw this thread the first time (wasnt here 10 years ago), nice to know this info.
Old 09-08-2012, 06:02 AM
amazing that the picture survived 10 years. they're usually gone.
206 637 4071
Old 09-08-2012, 06:57 AM
rw7810's Avatar
To me that looks like a cast iron gage.... seems to me any bearing I have used has a chrome moly polished type cage.
Robert Williams
70' 911T
Old 09-08-2012, 07:40 AM
Banned
It seems strange that someone's first post on Pelican is a commentary on a 10-year-old thread . . .
Old 09-08-2012, 11:20 AM
shark music......
206 637 4071
Old 09-08-2012, 11:26 AM
