-   -   Help with SWB Quarter window (http://forums.pelicanparts.com/porsche-911-technical-forum/703755-help-swb-quarter-window.html)
bobmspeedster 09-10-2012 10:01 AM
Hi all,
I am putting back together my 1966 911# 304014. I bought the rubber from Stoddard. The pieces they sent look like they should go in the quarter window body hole.. I don't see how they can work. On other 66/67 cars I have not seen this rubber gasket.
Maybe they sent me a fixed window rubber. Is there any rubber in the body itself or just the chrome lower piece and the upper piece and then the window frame rubber that just seals against the chrome and body.
I also need the rubber that goes in the chrome window frame.
Any ideas where I can buy this..
Also where can I buy the Top inside black trim piece that goes between the window frame and the body/headliner.
Any photos would help.
Bob Murray
Sac Ca
pdtweeks 09-11-2012 09:44 AM
Bob,
I'm doing similar project but with an '83 SC.....adding pop-outs to it.
There are a few threads (use search) with good info.
Parts diagrams are a big help too.
For trim along body flange, try part #'s; 999 911 041 00 & 901 543 423 00
pd
304065 09-11-2012 11:02 AM
Bob,
First, WELCOME to the forum. Looks like your car was made in March, 1966.
What part number are you describing?
What do you mean, quarter windows? Do you mean the rear side window, or the front opening vent window?
Porsche 911 Rear End Seals - Page 1
Pelican has a nice guide to the various rubber bits to help you better describe what you mean.
The pieces that go in the window frame, that previously were cloth covered metal, are no longer available and not reproduced by anyone as far as I know.
If you don't have the electronic parts catalog you can get it here:
http://www.porsche.com/all/media/pdf/originalparts/usa/911-1_USA_KATALOG.pdf
Good luck! There are many of us SWB owners on this forum.
