-   -   Weber Query (http://forums.pelicanparts.com/porsche-911-technical-forum/703796-weber-query.html)
DarthMJH 09-10-2012 12:08 PM
Weber Query
I have just replaced my Zeniths on my Euro 1973 911T with some refurbished Webers 40IDA 3C's.
The engine is fitted with a Bosch distributor with vacuum advance which connected to the Zenith carbs.
The Webers do not have a vacuum connection. Should i drill a hole in each manifold or remove the vacuum from the distributor ?
Many thanks
DarthMJH 09-11-2012 01:03 PM
I spoke with someone today who mentioned I could fit a Bosch distributor from a 911s which has no vacuum advance.
What would you recommend?
Steve@Rennsport 09-11-2012 03:38 PM
Personally, I would have the distributor recurved and run w/o vacuum advance.
DarthMJH 09-11-2012 04:02 PM
Thanks Steve
