1971 911 T C D I Ignition
Have a old Mark Ten B C D I Delta products unit that I need to replace, What should I replace it with? What works good? What All do I need in regards to new parts?
Thanks |
I would (and did) go back to the stock Bosch 3 pin CDI box in my 71, had debated on other things, MSD etc, even have a spare MSD box & blaster coil. but in the end decided to have the orig box repaired at Systems consulting (?) Santa Monica.
Works great, can post the proper name above if needed. The Bosh system works great. Regards |
Under the radar
MSD is another option, but there are issues with these. Do a search.
If it was me I would install a MSD or retrofit a Bosch 3 pin.
