Please Help, No Start issues
Been having hot start issues (86 Carrerra, 3.2L) and pretty much decided it is not the battery or ignition switch. Suspecting the starter motor/solenoid so I did some voltage checks last night.
Ok, here is some data I gathered last night. Any starter system guru thoughts?
Voltage (ignition switch "off")
1. Voltage b/w battery terminals: 12.57
2. Voltage b/w input from battery on solenoid and ground strap (GS): 12.57
3. Voltage b/w input from battery on sol. and yellow signal wire on solenoid (wire from ignition switch): 12.57
4. Voltage b/w input from battery on sol. and "pigtail" (braided copper wire extending from body of starter motor to solenoid): 12.57
5. Voltage b/w yellow signal wire and GS: 0.0
6. Voltage b/w "pigtail" and GS: 0.0
7. Voltage b/w yellow signal wire and "pigtail": 0.0
Voltage (ignition switch "on", by the way, thanks to whomever suggest the vice grips on the key with string to activate the switch!) First voltage is before I trigger the key, the voltage afterward follows the arrow.
1. Voltage b/w battery terminals: 12.57 --> 12.19 (dropped substantially, I know)
2. Voltage b/w input from battery on solenoid and ground strap (GS): 12.57-->12.19
3. Voltage b/w input from battery on sol. and yellow signal wire on solenoid (wire from ignition switch): 12.57-->2.05
4. Voltage b/w input from battery on sol. and "pigtail" (braided copper wire extending from body of starter motor to solenoid): 12.19-->11.62
5. Voltage b/w yellow signal wire and GS: 0.0-->10.16
6. Voltage b/w "pigtail" and GS: 0.0-->0.484
7. Voltage b/w yellow signal wire and "pigtail": 0.0-->9.8
Let me see if I can make that easier to read:
Before (off) After (on)
1. 12.57 12.57-->12.19
2. 12.57 12.57-->12.19
3. 12.57 12.57--> 2.05
4. 12.57 12.57--> 11.62
5. 0.0 0.0--> 10.16
6. 0.0 0.0--> 0.484
7. 0.0 0.0--> 9.8
Additional information:
When I turned the ingition key, I heard the solenoid click and when I would relax the key, I could hear the solenoid release.
Ran out of time beyond this, so the only thing I have determined from this is that it is most likely not the ignition switch (pulled the connector behind the dash and it looks fine (nice and clean).
I will compare these values to a Tech Article I saw based on some hot start issues.
Any thoughts from those steeped in starting system knowledge?
Old 06-04-2002, 07:18 AM
If I read your voltages right, you are not getting any power to the braid between the solenoid and the starter when the ignition switch is turned to start.
I had a similar problem on my 86. Turned out to be a poor join between the battery cable and the solenoid at the location where the battery cable bolted to the solenoid. If not that connection, it must be the solenoid.
Tim
Old 06-04-2002, 07:52 AM
