87 carerra intake/throttle body noise
I just started noticing excessive growling/bearing type noise that seems to come directly from intake/throttle body area. I hear noise when engine is at idle or when engine is on the way down to idle when coasting to a stop. With engine lid open, I can hear noise coming directly from intake/mass airflow sensor and is noticable from 800 to 1100 rpm. Have not experienced any power loss; engine still pulls hard in every gear. We are leaving on 5 state road trip soon; any input would be greatly appreciated. Have already checked engine air filter housing, it is snapped down tightly.
Old 09-03-2012, 08:55 PM
steely's Avatar
Feel the ICV and or listen to it with a screwdriver. I never heard of it making a lot of noise, but it is essentially a small servo motor. Maybe it is acting up. Might need cleaning or is on the way out. You could try disconnecting it after the engine warmed up as a test.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 09-03-2012, 10:48 PM
Hodgey's Avatar
jlewis:
have you tried the ambient air valve (AAV)? it sits forward of the oil filler neck, almost behind the deck hinge. It looks like a dome...simple to change...ask me how I know
I had the same noise as you. No big deal, just annoying I know.
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 09-04-2012, 05:23 AM
aerodyn930's Avatar
Follow the previous tips , If still unsure , Remove the fan/alt. belt then start the car, Rule out alt bearings,
Good luck, Lou
Old 09-04-2012, 05:44 AM
I used a long screw driver to locate noise, it sounds like it comes directly from or directly behind mass airflow sensor. It sounds like noisey valves but I just had them adjusted 2000 miles ago. It's kind of a rickety-clattering noise. Engine runs strong though, no performance issues at all.
Old 09-07-2012, 11:44 PM
Where is this valve located?
Old 09-07-2012, 11:45 PM
I will disconnect belt and see if noise goes away, but noise seems to come from up higher right from or behind mass airflow sensor
Old 09-07-2012, 11:46 PM
Thank you for the tip, removed the belt from alternator/fan and noise went away, getting alternator replaced today.
Old 09-15-2012, 11:15 AM
