Broken Clutch Cable
Coming home from Hayward, my clutch cable in my 72 911 broke. I carefully got the car home. Is there any special tricks I need to know when I change the cable?Bill |
Very simple but dirty job. Here is a link to the article on this board: http://www.pelicanparts.com/techarticles/911_clutch_cable/911_clutch_cable.htm
It does help to have small hands to disconnect the cable from the pedal mechanism.
Keitho64 05 GTO 00 911 C2 64 Corvair Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles |
Bill,
1. Be sure to have moly grease such as Valvoline #986, and a new clevis and pin/clip on hand when you start the repair! 2. Lubricate the new cable about 18" at a time as you feed the new cable into the body guide tube. 3. Be SURE that the Bowden tube (black plastic-covered sheath from firewall to transaxle mounting point) is fully seated at the 'dimple' in the firewall before adjusting freeplay at pedal. Good luck!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
I did this job in my 72 and it took me about 1.5 hours.
It's pretty easy. |
