87 carerra intake/throttle body noise
I just started noticing excessive growling/bearing type noise that seems to come directly from intake/throttle body area. I hear noise when engine is at idle or when engine is on the way down to idle when coasting to a stop. With engine lid open, I can hear noise coming directly from intake/mass airflow sensor and is noticable from 800 to 1100 rpm. Have not experienced any power loss; engine still pulls hard in every gear. We are leaving on 5 state road trip soon; any input would be greatly appreciated. Have already checked engine air filter housing, it is snapped down tightly.
Feel the ICV and or listen to it with a screwdriver. I never heard of it making a lot of noise, but it is essentially a small servo motor. Maybe it is acting up. Might need cleaning or is on the way out. You could try disconnecting it after the engine warmed up as a test.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
jlewis:
have you tried the ambient air valve (AAV)? it sits forward of the oil filler neck, almost behind the deck hinge. It looks like a dome...simple to change...ask me how I know ![]() I had the same noise as you. No big deal, just annoying I know.
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
Follow the previous tips , If still unsure , Remove the fan/alt. belt then start the car, Rule out alt bearings,
Good luck, Lou |
I used a long screw driver to locate noise, it sounds like it comes directly from or directly behind mass airflow sensor. It sounds like noisey valves but I just had them adjusted 2000 miles ago. It's kind of a rickety-clattering noise. Engine runs strong though, no performance issues at all.
Where is this valve located?
I will disconnect belt and see if noise goes away, but noise seems to come from up higher right from or behind mass airflow sensor
Thank you for the tip, removed the belt from alternator/fan and noise went away, getting alternator replaced today.
