-   -   Front end noise (http://forums.pelicanparts.com/porsche-911-technical-forum/70602-front-end-noise.html)
curlesw 06-05-2002 01:53 PM
Front end noise
My 83 SC makes noise in the front right portion of the car by the wheel whenever I start backing up and turn.:(
The car is completely stock, the PO did minimual upgrades. The sound is a deep clunking sound and does not seems to be coming from the brakes. Once I get going it stops (I guess...maybe I cant hear it because of the engine). I am sure there are some components that need replacing after 19 years but I do not know where to start..any ideas? Thanks.
Wayne
pbs911 06-05-2002 02:03 PM
Check the sway bar mounts to make sure they are tight and/or attached.
targa911man 06-05-2002 02:29 PM
If its rhythmic, maybe a loose/bad wheel bearing?
