SLR SLR is offline
SLR
915 second gear
Hi all and hope the sun is still shinning where you are!
I have had my 1985 911 sport for 11 years now and still love it as the day I got it.
I have not needed to do much work on it in that time. Just recently I have put new calipers discs, bearings and pads. plus new plug leeds, expensive suckers.
All the time I have had the car it has been a little bit of a job ( only some times ) going from 3ed to 2ed, not a huge problem. I'm an ok driver and know that this is an old gear box, but are a very good one. just over the last 2 to 3 months it's been steadily becoming more difficult getting through though's gears, and going from 1st to 2ed is getting more finicky. In the service book I see very early in it's life it had a 1st gear shaft and bits worked on, I would say bad gear changing.
There is no unusual noises nor grinding through the changes, I have tried changing revs but not much difference, I can change from 2ed to 1st why moving forward with no grornches or grinding.
Dose this sound as if there may be a sincro issue?
Sorry a bit long but what you think????
Thanks Steve.
Old 09-17-2012, 04:55 PM
pete3799's Avatar
Clutch adjusted properly?
Shift bushings all good?
Pete
79 911SC RoW
Old 09-17-2012, 05:01 PM
SLR SLR is offline
SLR
Thanks pete3799
clutch is ok as the last time I checked about 2 months ago.
shift bushings new.
thanks Steve.
Old 09-17-2012, 05:06 PM
SLR SLR is offline
SLR
The car dose have a factory fitted short sift, also when driving it is so smooth.
actually after adding new front wheel bearings the thing is notably smother, even though there was no sign of warn bearings?.
Old 09-17-2012, 05:13 PM
When was the last time you changed the transmission fluid?
Juergen
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
SLR SLR is offline
SLR
Autoban
year a while ago, I use Swepco, I will try that,
Servicing is something I stay on top of but not anal about it to the Km.
But trans fluid dose not get changed all that often.
Old 09-17-2012, 05:21 PM
I don't want to start a transmission fluid war, but I just changed mine and went from Swepco to Kendal and the shifting in and out of second gear improved. Mine is a '86 Cab with 70K miles on it. When I drained the fluid I didn't have any metal on the magnetic drain plug. This does not mean you will get the same results, but it is fairly inexpensive and quick to do.
Juergen
‘24 Audi Q8 etron
Old 09-17-2012, 05:31 PM
SLR SLR is offline
SLR
Hi Juergen
Thanks again. I haven't looked at Kendal oils yet, I'm not at my computer but what oil type was it?
Old 09-17-2012, 05:57 PM
I purchased here from our host. It's Kendall 80W-90 GL-5 NS-MP Hypoid Gear Oil.
Juergen
‘24 Audi Q8 etron
Old 09-17-2012, 06:49 PM
ivangene's Avatar
not all shift bushings are the same
BUT
adjusting can make even poor couplers work better - since you "just did it" I would advise re-visiting that
Kendall helped mine FWIW too
Ed M
86' Coupe
Old 09-17-2012, 07:15 PM
