PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Question Through the hood filler on SC, issues?
Anything I need to be aware when doing this on an SC with the CIS system???
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 09-18-2012, 02:59 AM
wachuko's Avatar
Do I have to adapt the vent system? Will I have issues with the pressure in the tank if I don't?
Drive safe!
1967 - Porsche 912
Old 09-18-2012, 05:03 AM
wachuko's Avatar
Back to the top.
I have to take the car this Saturday to the bodyshop and need to decide if I do the center filled conversion or not... reason for the question.
Drive safe!
1967 - Porsche 912
Old 09-18-2012, 06:55 AM
Call TRE. I'm pretty sure they can supply the parts you need and can tell you what you need to do to install this correctly. The last guy to do this didn't ask any questions before he installed the parts and he did it wrong.
JR
Old 09-18-2012, 07:22 AM
aerodyn930's Avatar
Hello Jaime, What tank setup are you using? Modified stock, Fuel cell?, Is the new cap vented? , I recommend plumbing in the vapor recovery system, You don't want fuel vapor in your garage at home!
Take care, Lou
Old 09-18-2012, 08:12 AM
wachuko's Avatar
Cool
Take care, Lou
Lou,
Using a new stock tank. Plan is to weld shut the stock fill location and weld the center filled kit.
That was my concern with the vapor recovery system. Excellent. Thank you.
Drive safe!
1967 - Porsche 912
Old 09-18-2012, 08:23 AM
wachuko's Avatar
JR
Dave has been very helpful. And I will be buying a few parts from him, but this is not one of those parts. I don't want to abuse of his willingness to help on a part he is not going to sell me... I just don't feel right doing that.
The kit he has is excellent, because in addition to the looks, it provides a locking cap under the old styled lid... but the cost reflects this. I found a less expensive alternative (without the cool locking gas cap, but budget dictates I go this route).
Drive safe!
1967 - Porsche 912
Old 09-18-2012, 08:38 AM
Do your parts allow for a good seal to the underside of the hood?
You might search for the other thread, as it discusses the tank venting issue. It was in the last month.
JR
Old 09-18-2012, 08:54 AM
I did this on my current SC a few years back without issue. The CIS doesn't care and the car runs just fine.
I too used the stock tank, welded shut the fill and cut a hole for the new neck. Pretty simple process.
I tied the factory vent back into the top of my new neck and formed a metal "bowl" around the new fill neck that channels water from the hole in the hood to outside the car.
I've driven through some incredible rain storms without a drop in the trunk.
I can snap a picture if you really need it, but this is a pretty easy modification if you let common sense lead you.
Vin
Old 09-18-2012, 09:00 AM
wachuko's Avatar
Vin,
If not too much trouble, yes, I would love to see photos.
Thank you,
Jaime
Vin
Drive safe!
1967 - Porsche 912
Old 09-18-2012, 09:26 AM
wachuko's Avatar
Vin,
I found your thread on this. Great!!!
center fill hood venting
Drive safe!
1967 - Porsche 912
Old 09-18-2012, 09:33 AM
JR
that would be me. I shaved the vapor lines off the tanks. it did not gave me any issues but i installed a tipover valve on the neck of the filer as I was sugested.
Just keep the vapor recovery system connected to the tank, and you wont get the faint gass smell i get once in a whille.
its a nice looking mod.
Old 09-18-2012, 01:05 PM
