help with green connector
hi guys , i need help with this green connector it is locate behind engine bay left side ,. can anyone tel me where should be connect . thanx
Old 09-16-2012, 06:25 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Warm up regulator?
1981 911SC Targa
Old 09-16-2012, 06:34 AM
dont think the wire is long enough to the wur
Old 09-16-2012, 06:39 AM
Bob Kontak's Avatar
1981 911SC Targa
Old 09-16-2012, 06:42 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Aren't the plugs/recepticles color coded?
Gary R.
Old 09-16-2012, 06:55 AM
thank you bob. i give a try tomorrow
i havent see the colour yet , because today i was focus on remove the ac system , but i wlll try to check up again tomorrow . thanx guys
Old 09-16-2012, 06:57 AM
Check your CSV......
I don't know any electrical plug with yellow wire from the wiring diagram except the one that goes to CSV. Take a look and keep us posted.
Tony
Old 09-16-2012, 07:05 AM
Bob Kontak's Avatar
Tony - the fat yellow wire is not on that plug. The pictures are a little deceiving.
Double checked my 81. The wire connector is gray on the WUR.
The connector to the cold start valve is bluish and the connector to the back of the air flow sensor is greenish.
This pic may be the one you need.
1981 911SC Targa
Old 09-16-2012, 07:29 AM
Poor eye sight......
Bob,
You are correct again!!!! The plug in question and the yellow wire are not related at all. When I first looked at the picture, the first thing that caught my attention was the 'yellow' wire. I stand corrected. Thanks.
Tony
Old 09-16-2012, 07:36 AM
kodioneill's Avatar
It would help to know the year but it may be for the cold start injector.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 09-16-2012, 09:20 AM
Red Line Service
Marc Bixen's Avatar
First what year is your car? In general I don't recall a "Green" plug, so someone may have replaced the connector at some point. I'd recommend pulling back the rubber boot and identifying the actual wire color codes, then comparing it to the wiring diagram. And yes that photo is deceiving, it looks like someone put an EFI plug on the heater blower wiring.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 09-16-2012, 09:23 AM
Red Line Service
Marc Bixen's Avatar
There are a total of , I think 5 of those type connectors on later SC's. Air slide (between cyl 5 &6 intake), Safety switch (on the sensor plate assembly), Frequency valve (in line on the fuel return line), Warm-up regulator, and cold start injector. See where it seems to fit to, the safety sw has brown wires, the cold start yellow.
Old 09-16-2012, 09:28 AM
Red Line Service
Marc Bixen's Avatar
I have a feeling it's from the safety switch. This is to shut off the fuel pump in the event of a roll-over. Simple test, ignition on, car not running, does the fuel pun run? The FP should only run in this condition if you lift the sensor plate.
Old 09-16-2012, 09:38 AM
sorry guys . my car is 80 sc
Old 09-16-2012, 06:37 PM
Red Line Service
Marc Bixen's Avatar
Still check the safety switch on the rear of the sensor plate housing. You can look with a mirror or feel around back. If it's NG you'll hook it up and the car won't start, disconnect it and the car will start.
Old 09-16-2012, 06:44 PM
Bob Kontak's Avatar
Check the picture I posted of my 81. The plug shell is greenish on the safety switch. It is not going to make it to the AAR and kj9438 confirmed it does not make it to the WUR. Freq valve is black and cold start is blue.
1981 911SC Targa
Old 09-16-2012, 07:21 PM
Old 09-16-2012, 07:38 PM
Wire color.......
kj,
Could you check the color of the wires connected to this 'green' electrical plug? Slide the rubber boot insulation and you'll see the color of the 2 wires connected to the plug. These are the five (5) electrical square plugs in the engine wire harness:
WUR........red/white and brown wires.
AAR.........red/white and brown wires.
CSV.........yellow and red/black wires.
AFS.........black/brown and brown wires
FV...........black/red and black/red wires.
Keep us posted.
Tony
Old 09-16-2012, 08:27 PM
El Duderino
tirwin's Avatar
I *think* that is the sensor plate contact plug. Does the fuel pump run with the key in the on position? It's not supposed to but will if it will if the sensor pate is unplugged.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 09-16-2012, 08:49 PM
