-   -   Installing Heet Sheets (http://forums.pelicanparts.com/porsche-911-technical-forum/70680-installing-heet-sheets.html)
PDACPA 06-06-2002 02:45 PM
I looked under the car to see about the Heet Sheets that I ordered from Pelican.
Passenger side has easy access and looks very clean.
Drivers side has an obstruction (is it the cat?) but the place where the Heet Sheet is installed looks like its covered in oil. Where would this be coming from?
Roland Kunz 06-14-2002 02:16 PM
Hello
What are heet sheets ? ( Sorry I´m a stranger )
Are those the cool coolars to hang onto the valve covers ?
Oil comes mostly from the engine. On the passenger side it is possible leftovers from spill while fill but on the driver side it is mostly the valve cover.
Grüsse
911pcars 06-14-2002 11:53 PM
PDACPA ,
You didn't expect all 9+ quarts of oil to stay inside the engine did you? Many owners have completely dry engines. My hat is off to them as there are many avenues in our engine for oil to escape to the outside world. And due to earth's gravity, most of it moistens the bottom half of the engine on it's way back to the ground from whence it came. I suspect your oil is leaking from one or more (maybe all?) of these known areas:
- oil pressure switch
- engine thermostat
- cam housing oil lines
- upper valve covers
- crankshaft end seal
- flywheel end seal
- joint, engine case halves
- engine oil cooler seals
- oil drain tubes (4)
- cam housing-to-cylinder head joint
- camshaft chainbox seal
- rocker arm shaft(s)
- lower valve covers
- oil lines to/from oil tank
- oil sump plate
There's probably a few more areas I missed.
One way to find these leaks is to clean the engine (top and bottom), run the engine, then look for the fresh oil leak path(s). Another method, mentioned in a recent post, is to use a dye in the oil which is then easily seen with a black light. I had an oil leak that looked like it was from the driver's side cam housing-to-cylinder head joint. For months I was psyching myself up for an engine drop and D&A to fix this but soon realized the cam housing line was leaking at the hose fitting behind the distributor. I snugged it up (1/4 turn!) and now have one less leak source. Hey, it's better than plan A.
One nifty side benefit I've discovered (and what many customers don't like to admit) is that the lower bend of the HeetSheet acts as a gutter of sorts. Oil that once dripped indescriminately on the heat exchanger now collects in the sheet metal fold, flows in a fore or aft direction, then drips onto a specific area of the exhaust system. This is a definite improvement in external oil management over what the factory provides. :)
Roland,
I guess you haven't yet been blitzed (blessed?) by my multi-level product media campaign. Seriously, HeetSheets are modeled after the Porsche Motorsport versions to reduce the temperature in the lower valve cover area created by exhaust heat; in the case of 930s, heat generated by the turbo; in the case of later 911s, heat also generated by the catalytic converter. Temperatures can be 400ºF+.
http://www.seinesystems.com/Images/GT2HeatShield.jpg
Porsche Motorsports heat shield
http://www.seinesystems.com/Images/HeetSheet-L.jpg
HeetSheet on early 911 w/SSI heat exchangers
Regards,
Sherwood Lee
http://members.rennlist.org/911pcars
Roland Kunz 06-18-2002 11:51 AM
Hello
I see its a cool coolar thing ;)
The Porsche Motorsports heat shield makes sense as it is a other situation then the normal angine has.
The background was that the aerodynamics didn´t allowed to much turbolence to cool the "hot spots" and on the other side the turbo chargers have a much hotter exhaust then the street 930. They became hot enough to draw enough heat to warp the thin aluminium valve covers wich would lead to higer oil consumption wich would lead to lose races ;)
OK race engines are dual pluged and i think the powerloos by melting down ignition wires would avoid to overhat that area seriously ;)
On the other side race engines don´t need to be cooled like street engines as they have a complete other thermodynamical layout and mostly run plenty oil trough giant coolers using efficient high volume pumps working at higher revs and having enough fresh air rushing trough abouve the average highwayspeed.
Something a normal 911 will not see to often to cool down.
( officer; Why where you driving that fast ?
You: I had to cool down the engine ;) )
Grüsse
JonT 06-18-2002 12:29 PM
So are these a recommended add-on or not?
island911 06-18-2002 12:29 PM
Ouch! :eek: Foiled by an Absolute Beginner. :D
EDIT: . . .or is it Foil from an Absolute Beginner? :rolleyes:
Roland Kunz 06-19-2002 05:37 AM
Hello
From my sight they look nice and are easy bolt ons for amatures.
But I wouldn´t use a comparson to a race car to justify there need.
Its a cool coolar thing.
The catalyt converter can become very hot under full load and should stay hot even at idle to work efficient.
In fact they are shielded to keep them warm at idle and avoid to burn something under the car if parked without care.
( japan versions needed full shielding )
So in fact at idle there is heat draped into the isolatin shielding from the catalyt and that heat also lowers the heat disapation from the lower left valve cover.
Now I still wounder how the heat sheet works. It is aliminim and mountet to the valve cover and just adds more heat sink and colling surface but it isn´t a full shield like on the race versons and so enough hot air will be drown behind it plus the upper area from the valvecover is still under direct heat radiation.
Grüsse
PDACPA 06-19-2002 06:49 AM
My personal opinion (and I bought them) was that they would provide a small useful function and I liked how they looked under the car (totally useless reason to spend $70 but I liked the little extra dress up touch even if u only see it by crawling under the rear bumper, but people do that to P cars).
tshih 06-19-2002 07:47 AM
Heet Sheets
Originally posted by Roland Kunz
Hello
Grüsse
I agree with Herr Kunz,
The fact that aluminum can act as a heat sink makes this a dressup proposition. I personally prefer to attach a different piece of aluminum sheeting that would be designed to scoop cool air and channel it over the valve cover areas like the COOL BRAKES products racers use for their brake cooling enhancements.:rolleyes:
widebody911 06-19-2002 08:25 AM
So why not make them out of titanium? :)
island911 06-19-2002 08:29 AM
Hey, even better; I have a piece of titanium honeycomb about the right size.
That's it! and at only $1200 per side I'll be rich . . .muhaahahah
5axis 06-19-2002 08:57 AM
1 Attachment(s)
I tend to think these may be much more beneficial than the CC.
If I recall correctly they are constucted of SS #?? for it's thermal properties. I think they may help some of us. I bet it would help this turbo :D
http://forums.pelicanparts.com/showthread.php?s=&threadid=65791&highlight=glow+AN D+turbo
david 89 turbo cab
Superman 06-19-2002 08:58 AM
From time to time Boeing sells sheets of .040" titanium from their 'surplus' store for I believe $8 per pound. Sheets between 2 and 3 feet per side weigh about 7 lbs, according to my recollection. Machinists hate to work with this stuff, but those thinner sheets might not be too bad. And titanium shields heat like nothing else (except space shuttle tiles).
5axis 06-19-2002 09:09 AM
Hey Super, Ti and SS both tend to be a PIA to machine. They are what we describe as GUMMY . The material loads up on the cutting tools and the cutting edge fails. They make lots of specialised tooling for this stuff that costs a lot and only works a little better. :rolleyes:
tshih 06-19-2002 10:27 AM
Guys,
The only real way to settle all this heat shielding and necessity of additional cooling is to attach a thermocouple heating sensor to the valve cover (with and without the heet sheet attached and run the car under normal conditions and see what the temperature says on the probe. Then you can all see the real effect of the modification.:rolleyes:
911pcars 06-19-2002 11:19 AM
tshih,
I have done what you suggest with heat sensitive thermal strips. I installed a short length of metal off of one valve cover stud to help isolate engine vs exhaust heat, then stuck the thermal strip onto it. My preliminary results: front of shield = 260º, back of shield = 220º. During long term testing under hotter weather and extended driving conditions: front of shield = 300º, back of shield = 220º. Engine tested is 2.7 w/RS P&C, Webers and E cams. Your results may vary. BTW, surface temps from my factory heat exchangers next to the valve cover were close to 400ºF at idle. Engines with catalytic converters and turbochargers will most likely be hotter (though not tested).
Similar testing was performed at the driver side chain box cover. Heat coming off the muffler is not as hot and I measured 220º at that location as well which means a shield at this location is not necessary. However, I did have to fashion a shield between the muffler and the rear license plate panel (proximity much closer) as the paint was bubbling.
Aluminum can act as a heat sink if there is a cooler area for the heat to go. Unfortunately, compared with the exhaust system, the cooler area is the engine itself which is largely aluminum, and we know how well it dissipates heat by the oil temperature inside of it.
Titanium is a nice material for a shield, but there is a cost/benefit equation for stainless steel that Ti doesn't provide at this point (for customers). A Ti HeetSheet does sound racey though.
Sherwood Lee
tshih 06-20-2002 06:28 AM
Sherwood,
You're right about SS being better for economy than titanium but the best flat sheet shielding material would be ceramic (non-conducting!) and lightest of all. I still think installing a bigger front oil cooler and letting the engine oil and dry sump system do its job of moderating metal temperature through out the engine area is the best solution for engine longevity.
Tom
jpachard 06-20-2002 10:54 AM
Hmm, I have had no problems machining Ti. You just need to RTM(read the manual ie. Machinery's Handbook). I used to machine 6Al-4V for the bicycle and aerospace industry as well as CP(commecially pure) and 6Al-2.5V. It's actually easier than some of the high grade stailness steels(17-4pH comes to mind). Where do I go to get these surplus sheets from Boeing???
Cheers, James
911pcars 06-20-2002 11:11 AM
[b/]"....I still think installing a bigger front oil cooler and letting the engine oil and dry sump system do its job of moderating metal temperature through out the engine area is the best solution for engine longevity."[/b]
I agree. I have no issues with that. However, the exhaust system, which transports approx. 60% of the heat energy from the combustion process, is not doing the cooling system any favors due to its close proximity to the engine. Wouldn't it be nice if the temperature of the bottom of our engines was the same as the top end?
Sherwood
Hellgate 06-20-2002 02:16 PM
I heard that if you buy two of these they will throw in a sequencial ERAM to boot!
tshih 06-20-2002 03:38 PM
Sherwood,
I think Porsche has introduced ceramic liners in the exhaust manifolds of the later 911, 944 turbo, 928 etc to combat heat extraction and added insulation. The operating temperature of most Porsches in motion not stuck in traffic jams are all within specs despite the proximity of the exhausts. So why worry about not having cooling during being stuck in those kinds of situations. I'd rather be blasting around at high speeds with the temp gauge reading 190 deg F. :)
Tom S.
RSupdate 06-20-2002 04:25 PM
Just for the record, I installed a set of Sherwood's Heetsheets in about 20min total...and I'm a slow-poke.
I bought them because they are a good additional 1% "so to speak" in the chain of reducing heat radiation back at the engine.
I figure that several small improvements like this will add up to a small yet noticable reduction in oil temp overall.
Just my .02
911pcars 06-20-2002 04:43 PM
"I think Porsche has introduced ceramic liners in the exhaust manifolds of the later 911, 944 turbo, 928 etc to combat heat extraction and added insulation."
Tom,
Those ceramic port liners are missing in most 911s until they appeared in the very latest engines (993s?). So many of us don't have the benefit of those. Besides, I think the factory installed them mainly for OBD II requirements; quick warmup time for low emissions from the cat.
"The operating temperature of most Porsches in motion not stuck in traffic jams are all within specs despite the proximity of the exhausts. So why worry about not having cooling during being stuck in those kinds of situations.
I'd rather be blasting around at high speeds with the temp gauge reading 190 deg F."
From the many responses on this forum, owners report oil temperatures of 230-250º. This may be within "factory specs" but it doesn't help engine longevity operating at this level.
Not sure what the weather and traffic patterns are like in your area, but I'm in So. Calif. When it's hot, the traffic is usually stop-and-go. I usually reserve the blast when I can get out of the city .... or late at night when the only "heat" is just a radar blip away.
Hellgate,
You'll have to supply your own eram(s). BTW, anyone ever think of using this to supply a large quantity of hot air to the cabin? Might be enough to dry clothes.... while you're wearing them.
Regards,
Sherwood
Roland Kunz 06-21-2002 02:31 AM
Hello
First car with Ceramic Portliners and first use in a street automobile = 951 in 1985
First 911 with Ceramic Portliners = 964 in 1989
Grüsse
ChrisBennet 06-21-2002 04:32 AM
I made my own heat shield to protect the lower plug wires from the heat of the cat. It's not pretty but it does the job until I get a nicer one made.
-Chris
http://forums.pelicanparts.com/uploads/heatSheild1.jpg http://forums.pelicanparts.com/uploads/heatSheild2.jpg
