-   -   Exploded Engine Pic... (http://forums.pelicanparts.com/porsche-911-technical-forum/70730-exploded-engine-pic.html)
Wayne 962 06-06-2002 07:34 PM
http://forums.pelicanparts.com/uploads/engine2.jpg
Ha, made you look!
-Wayne
Jim Sims 06-06-2002 07:55 PM
Okay, let's play a game. What parts are missing from this image?
Cheers, Jim:D
scca_ita 06-06-2002 08:08 PM
wrist pins
boyo 06-06-2002 08:10 PM
Spark plugs!
Actually, I was expecting more carnage... :D
-Boyo
Doug Zielke 06-06-2002 08:11 PM
A bucket full of fasteners.
(There ain't gonna be no rebuild without 'em!)
Superman 06-06-2002 08:16 PM
Bearings.
Victor 06-06-2002 08:19 PM
About 13L of Oil.
Jim Sims 06-06-2002 08:25 PM
Superman, Surely you remember that seal carrier between the chain case and cam tower! Case through bolts, nuts, washers and o-rings. There's plenty more besides fasteners. :D Jim
TedSlick 06-06-2002 08:27 PM
it all looks so...simple [gulp]
http://www.pelicanparts.com/support/smileys/loki5.gif
nostatic 06-06-2002 08:28 PM
A case of Becks and a pair of vice grips.
BlueSkyJaunte 06-06-2002 08:36 PM
...don't forget the 20-lb. sledge for final adjustments.
emcon5 06-06-2002 08:39 PM
Distributor cap and sump plate?
Tom
Doug Zielke 06-06-2002 08:44 PM
Now this, kiddies, is a real "exploded motor".
You don't want to know what the insides look like.....
http://forums.pelicanparts.com/uploa...kcase_hole.jpg
Adam 06-06-2002 08:53 PM
I'll tell you what's missing!
Alloy 930-spec valve covers to replace those leaky Mg units... :(
Jim Sims 06-06-2002 08:55 PM
Doug, Send that puppy out to CE; they'll weld it up, line bore it, put in case savers the size of your big toe and it'll be good as the day it was squeezed into the mold. :D Jim
Wayne 962 06-06-2002 09:01 PM
Not so fast...
Those are Turbo valve covers - just painted black.
Wrist pins are inside the pistons...
-Wayne
Wayne 962 06-06-2002 09:03 PM
<big>THIS IS WHAT WILL HAPPEN IF YOU DON'T BUY MY NEW BOOK!!!</big>
http://forums.pelicanparts.com/uploads/engine3.jpg
Good scare tactics, huh?
-Wayne
CamB 06-06-2002 09:22 PM
I posted one on Wayne's other thread - its big, so I'm not going to up the bandwidth on this page too:
http://forums.pelicanparts.com/porsche-911-technical-forum/70736-looky-here-rare-911-s-rod.html
I reckon "my" (fortunately not!) pic is better, just not as dirty :D :D :D
Doug E 06-07-2002 02:36 AM
Wayne - out of curiosity, what causes the type of damage shown in the "scare tactic" picture above?
VenezianBlau 87 06-07-2002 03:53 AM
...Wayne and his minions scurry through the night and swipe your intake valves...
Wayne 962 06-07-2002 05:10 AM
After examining this engine, I discovered that the crankshaft was cut to an English undercut (0.010" under, which is not a metric size), probably from a shop that doesn't know anything about Porsches. Not sure if that contributed to the failure, but if a gross mistake like that was made, I'm sure the rest of the engine was crap.
The only thing semi-salvageable from this engine was the updated idler arms...
-Wayne
