-   -   Time to Re-Think? (http://forums.pelicanparts.com/porsche-911-technical-forum/707424-time-re-think.html)
nvr2mny 09-21-2012 03:31 PM
Time to Re-Think?
Guys/Gals, what would you do? I've got a '69 912 non sunroof coupe without an engine/trans that is very straight and almost rust free. It has a complete correct interior (orig slate gray w/black int) that I was going to turn it into a hot rod with the Polo engine set up. In beginning the teardown process I've discovered that the front clip was replaced many moons ago. The welds look ok, but how do I know? It has kinda soured me on using this car as the candidate for this build project. What do you think? Strip it and move on, or continue? http://forums.pelicanparts.com/uploa...1348266669.jpg
http://forums.pelicanparts.com/uploa...1348266686.jpg
Spede 09-21-2012 03:34 PM
It depends on you because you have to live with it but personally I'd look for a better platform to build on.
RWebb 09-21-2012 04:03 PM
I'd get an expert in welding to look at it.
wasserkuhl 09-21-2012 04:29 PM
Those welds do not look Ok.
I would want to be taking all that back to metal and inspecting and then repair if economically viable. Worth it if you are doing a resto back to factory..........These are special Cars.
nvr2mny 09-21-2012 08:18 PM
I agree, I need to get an experts opinion. Thanks for the input.
Evans, Marv 09-21-2012 08:30 PM
If you are going to spend megabucks on a Polo, you might as well locate a good tub. By good I mean almost flawless in your case. If you have the engine & transmission, you could put them back in & sell it to somebody who would like it as is.
Ramathorn 09-22-2012 08:10 AM
Maybe its just me but, how can you guys tell the welds are no good? I guess my untrained eye it just looks like a weld with that rust proof coating garbage on it. Id say strip that stuff off and then see what you are working with if youre like me and not and expert have someone take a peek at it.
Ramathorn 09-22-2012 08:17 AM
Oh back to the question, Since its a 912 i honestly wouldnt worry to much about it. That in itself is gonna hinder the resale if you ever decide to part with it.
Its a tough question to answer, to me i would find a 911 if i was gonna go the porsche purist route and the driver/ builder in me says eff it, clean it up...build it....drive it!
al lkosmal 09-22-2012 08:59 AM
With a welded on clip.....it would not make sense to me to consider this as a restoration project......but if, after an inspection of the welds, it turns out to be structurally sound or can become structurally sound .....i'd continue down the hot rod path. It sounds like the rest of the car is in good shape.
1990C4S 09-22-2012 10:17 AM
I am a welding engineer, or used to be. 'Looks okay' are two words I never like to hear in regards to a structural weld.
Grind it out and get it professionally welded and inspected. It might be fine, it probably is, but I wouldn't assume it is.
al lkosmal 09-22-2012 10:32 AM
Originally Posted by 1990c4s (Post 6991239)
i am a welding engineer, or used to be. 'looks okay' are two words i never like to hear in regards to a structural weld.
Grind it out and get it professionally welded and inspected. It might be fine, it probably is, but i wouldn't assume it is.
+1
HawgRyder 09-22-2012 10:35 AM
In my experience...if you can see that it has been welded at all...then it's probably NOT a good job.
I have seen welded assemblies that for all purposes are one piece.
I had to be told it was more than one piece joined together.
Bob
Steve@Rennsport 09-22-2012 12:25 PM
IMHO, that's a very poor job of clip replacement and I'd be looking for another donor for a project car.
I've seen such work before and you can really see how badly they are done on the alignment rack.
77TARGAV8 09-22-2012 01:34 PM
If I welded it, I you could barely notice it when I was done. The correct klecos and a mig with minor grinding would not look like that. My .02.
Matt Monson 09-22-2012 03:57 PM
Most people didn't consider this little 912 worth saving either. I'm just saying...
http://forums.pelicanparts.com/porsche-911-technical-forum/345183-swb-911r-beginning.html
porsche930dude 09-22-2012 07:06 PM
does look a bit boogered up. I agree clean it up and inspect it you can probrobly fix it up to an acceptable level. as long as the front end measurements are somewhat in spec. Its no worse than people replacing entire sections of a rusted out chassis.
