Send a message via AIM to 82SC
CO adjustment screw...where?
can some one tell me which one is the mixtrure screw??
Mine is running rich and I wanted to take it down a couple notches....
also I am assuming that this can be done with a long allen wrench???
thanks
MJ
Old 06-07-2002, 12:29 AM
Steve W's Avatar
Under plug #14 there is access to the adjustment screw on arm #8. I forgot what size allen wrench you need in there, but it is something like 2 or 2.5 mm. Some CIS meters don't have a pull up plug like #14, but actually an aluminum plug sealing it instead. If that's the case, you will need to drill a small hole in the plug, thread a coarse thread wood type screw into the hole, and use some pliers to pull it out.
Old 06-07-2002, 12:56 AM
Bigbartguy's Avatar
once the plug is off (may already be off anyway), you'll need to use a 3mm wrench.
Tim
1985 Targa
Old 06-07-2002, 09:09 AM
