Quest for cool part 2a
Well, I have installed the second oil cooler in the left front and installed SPAL fans on each cooler. The addition of the second cooler lowered the temp by 1/4 inch, and the with the fans on, it stays in the middle! Hence the next request. My temp gauge does not have numbers on it, so could someone take a pic of the gauge so i can see where my temps really are??? (im going to change to a numbers style soon!)
thanks, Marc Sorry to Jack for stealing your title! |
Centrigrade equivalents of each mark are written in extremely tiny digits way over to the side at the base of the lines. A magnifying glass and a lot of patience may be in order.
In a previous post about this, Emcon5 wrote: Quote:
This is from a web page I found: Quote:
------------------ Jack Olsen My Rennlist page • My Pelican Gallery page • My Porsche Owners Gallery page |
Marc,
There is a slightly less expensive alternative to the numeric P-gauge. Tweeks (Pelican maybe, Idunno) sells a sending unit that has connections for the stock gauge AND for an aftermarket round gauge. If you are using a gauge cluster or have a spot for one this might work for you. (I saw this setup recently on a modified 930). Why do that, you ask? Well - it gives you the option to use a gauge with a more desirable temp range. The full 280 semi-circular sweep on this gauge went to 250F max, like you would see in an American car. I just like a more usable sweep, easier to see the needle move. Haven't decided if I'll get one myself yet or just upgrade the stocker. On my stock gauge I can barely see those little numbers stuck in the corner. You'd think as long as they were printing them they might be put where you could see! [This message has been edited by RarlyL8 (edited 08-12-2001).] |
My 88 coupe typicall runs an arrow width 1/16- 1/8 inch above the mark about in the middle. Does that equate to 260 deg. F ? Seema alittle hot to me.
Where does your dial lever (Arm) average on a normal run say after 15 min. Above- below the middle mark, how much ?? |
| All times are GMT -8. The time now is 06:18 PM. |
