-   -   Correct 69 latch plating (http://forums.pelicanparts.com/porsche-911-technical-forum/707660-correct-69-latch-plating.html)
kkinzli 09-22-2012 07:02 PM
What color should the latches (hood and decklid) be plated on a 69? I have seen both yellow zinc (originally cadium) or a silver zinc plating. Thanks in advance!
Cheers,
Kristoph aka Ratman
Classic 09-23-2012 02:33 PM
My late build ROW 69 has/had clear, or silver with gold hardware affixing them to the body
Daves911L 09-23-2012 05:04 PM
Kristoph,
I walked out this afternoon and looked at that old '72 down in the pasture. It is just as Classic describes his '69. Silver colored plating on the latches, held in place with gold-colored hardware.
DG
kkinzli 09-24-2012 05:32 AM
Originally Posted by Daves911L (Post 6993419)
Kristoph,
DG
Thanks Classic and David!
I will check with the plater if they can do two seperate batches. If it is too expensive to seperate I will go with yellow zinc for everything.
