How to remove accelerator pedal
Hey all,
I'm trying to remove the pedal so I can put an aftermarket one on how do you remove it ? Thanks in advance |
Got the screw out but can't get the connector off any ideas?
The connector is just a ball that goes into a socket on the pedal. Takes a good tug to remove it, you may have better luck putting the bolts back in so you can leverage it back.
-Rutager |
Pop the ball out by yanking the pedal toward where you would be sitting when driving and then unbolt it from the floor.
| All times are GMT -8. The time now is 04:00 AM. |
